In reply to my crash, it was about 37km into a 40k stage, just gone though a double caution crest into a Left then Right downhill. road was quite slippery and felt the tail start to slide out, it dropped into the culvert and spun the car and the lhf climbed the bank and flipped the car. slid on the rook for a while as i think we were doing about 80km/h.
have cut the roof off and welded a new roof on it, and just need to replace the front radiator support and headlight support.
  • 1 month later...
  • Replies 169
Posted Images
Ran the AMSAG Orange City Rally 2 weeks ago and was hoping for another strong event in the Silvia. This event was part of the 2WD Master Series also so there was a big field with plenty of competition. I was really looking forward to the competition and to see if we could continue our good run. I was seeded first on the road because of my win in the last event so was a little bit worried about sweeping the loose gravel. Unfortunately i never got to finish stage 1 the gearbox decided it had enough and let go about 4km out from the end of the first stage which was about 27km long.
Luckily we had the incar footage so we could at least compare our time against some of the other top runners after the event. It showed we were definitely on the pace and looked like we would of won the 1st stage by at least 20 seconds.
Will be now spending some time on building up the gearbox it was the last part of the car that needed upgrading but i was hopeful it would get us through this season. Looks like ill be getting an Albins gear set hopefully that will be a big improvement.
Incar of the first stage.
Been keeping an eye on your progress from here in NZ, the Silvia is looking good. Looks to be fairly torquey pulling from low down out of some of those turns. Quite a contrast to my revvy N/A that I have to keep strung out up on the cams, good fun though.
First pic above. Is that brake smoke coming out of the front wheels? Must have been a pretty big stop coming in to there.
It's not bad, on the road it pulls from about 2500rpm all the way to 7000 and is fairly linear. On the dirt though and with altitude you do loose some of that response, but it is pretty impressive and very rarely do you find it bogging down off boost even when you get it a bit wrong.
The ratio in the gearbox from 2nd to 3rd is the only time you notice bogging down slightly if on a hill put its not bad and still pulls, which will now be fixed with the new gear set
I'm only running the car on 10psi of boost I've run it once on 17psi but its just undriveable, its bad enough keeping the rear tyres on it.
  • 3 weeks later...
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
