Not at all, I really appreciate the help :) I didn't intend to set this up so that other people would have to do my work for me, but it's very helpful when my FAST is being temperamental. Once it's back up in business, I should be good with the possible exception of going on holidays ;P
  • Replies 86
Got another one, bit no VIN for a GTR :(
looking for the part numbers of the plastic surrounds for the front blinkers - the mesh ones apparently can be bought separately so im keen to price them up.
owen, any chance of a DVD copy of fast installer?
Looks like the LH side part has two part numbers, depending on the year of the GTR?
yeah - series 3 GTR had a bigger vent hole
thats awesome, thanks heaps
woohoo $65 for the pair ex melb :P
  • 1 month later...
  • 4 weeks later...
Hey mate, I was just after some part numbers for these parts. Manual Gearbox Surround Cover to suite a 2D R34 25GT, and the two panels on each side of the centre console (not sure what they're actually called, hence why I have attached images. :P)
Anyway, as you can see they've been scratched to shit by the previous Japanese owner, so I want to get them replaced. :D
Cheers, cpd.
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
