Heya;
i know absolutely nothing about boost controllers. i hope; by the time i've had a bit of a read i'll be a little more enlightened; but additonally; i need reccomendations on which is best suited for what i
will use it for.
the cars a 34 gtt S2;
I've been speaking with people at RE customs in vic; the plan is nothing ridiculous; i'm aiming for that stage 1 upgrade as its called; that squeezes the most out of the stock parts without costing a fortune.
*air intake: done
*free flow exhaust: done soon
*boost control: planning stage
I've read the info on what i should be expecting to get out of the stock bits; so looks like i'll be dialed up to about 10 psi and left there. from my understanding that's barely using them.
The mechanic at RE was saying when they do the install; they'll give it two settings; one for the stock (and reliable :rolleyes:) factory setting of 7psi and the other their upgraded settings.
So that would be the only requirement of the controller. it would need to have the ability to switch between two settings and uuuh thats about it. i don't really want to play with the thing.
a mate of mine is offering to sell me his used gizzmo electronic controller with solenoid for around 200 bucks.
i know so little about the thing i'm in danger of jumping into a bad deal. since the whole thing hinges around this solenoid; is it a bad idea to buy a used one? would the gizzmo be appropriate for what i need?
Any advice; much appreciated.
Gready profic type II. A little hard to set up if you are a first timer but nothing your tuner cant do. Great quality, not overly expensive and probally one of the better ones on the market! Mine hasn't givin me any trubble but im only in my first stages of modifying the engine.
For a basic set up like your doing there is no need to spend much cash on boost control
get one of these.....
http://www.skylinesaustralia.com/forums/topic/73375-i-found-a-good-cheap-boost-controller-for-22/page__hl__loose
if you just want one setting, then change the actuator spring
no need for a controller at all
also
running dual stage boost or "high" and "low" just allows for failures and over-boosting
ie if you cant safely run "high" then why run it at all?
run and set the car for the highest safe setting and control the car with your right foot
All the options above are possible but for a good ebc that will see you through future mods a gizzmo is good value, $275 delivered off ebay every day of the week!
buy ur mates gizzmo boost controller, it's good
Turbotech for cheap bang for your buck or Gizzmo if you want electronic controller (also acts as a boost gauge I think, so no need to buy a separate gauge).
It is a boost gauge but does not show vacum if that matters.
hks and greddy boost controllers are always going to be popular and preform well.
currently I've been using Ark Advanced Boost Controller and have to admit i love the thing, had to have a good read of the manual for adjustment - but after that it was straight forward
was waiting for someone to say a turbo tech they are brilliant 30bucks from ebay and if your not pushing for to much power they are great just bleed 2-3psi out of it and you should be fine.
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
