Heya;
i know absolutely nothing about boost controllers. i hope; by the time i've had a bit of a read i'll be a little more enlightened; but additonally; i need reccomendations on which is best suited for what i
will use it for.
the cars a 34 gtt S2;
I've been speaking with people at RE customs in vic; the plan is nothing ridiculous; i'm aiming for that stage 1 upgrade as its called; that squeezes the most out of the stock parts without costing a fortune.
*air intake: done
*free flow exhaust: done soon
*boost control: planning stage
I've read the info on what i should be expecting to get out of the stock bits; so looks like i'll be dialed up to about 10 psi and left there. from my understanding that's barely using them.
The mechanic at RE was saying when they do the install; they'll give it two settings; one for the stock (and reliable :rolleyes:) factory setting of 7psi and the other their upgraded settings.
So that would be the only requirement of the controller. it would need to have the ability to switch between two settings and uuuh thats about it. i don't really want to play with the thing.
a mate of mine is offering to sell me his used gizzmo electronic controller with solenoid for around 200 bucks.
i know so little about the thing i'm in danger of jumping into a bad deal. since the whole thing hinges around this solenoid; is it a bad idea to buy a used one? would the gizzmo be appropriate for what i need?
Any advice; much appreciated.
Gready profic type II. A little hard to set up if you are a first timer but nothing your tuner cant do. Great quality, not overly expensive and probally one of the better ones on the market! Mine hasn't givin me any trubble but im only in my first stages of modifying the engine.
For a basic set up like your doing there is no need to spend much cash on boost control
get one of these.....
http://www.skylinesaustralia.com/forums/topic/73375-i-found-a-good-cheap-boost-controller-for-22/page__hl__loose
if you just want one setting, then change the actuator spring
no need for a controller at all
also
running dual stage boost or "high" and "low" just allows for failures and over-boosting
ie if you cant safely run "high" then why run it at all?
run and set the car for the highest safe setting and control the car with your right foot
All the options above are possible but for a good ebc that will see you through future mods a gizzmo is good value, $275 delivered off ebay every day of the week!
buy ur mates gizzmo boost controller, it's good
Turbotech for cheap bang for your buck or Gizzmo if you want electronic controller (also acts as a boost gauge I think, so no need to buy a separate gauge).
It is a boost gauge but does not show vacum if that matters.
hks and greddy boost controllers are always going to be popular and preform well.
currently I've been using Ark Advanced Boost Controller and have to admit i love the thing, had to have a good read of the manual for adjustment - but after that it was straight forward
was waiting for someone to say a turbo tech they are brilliant 30bucks from ebay and if your not pushing for to much power they are great just bleed 2-3psi out of it and you should be fine.
    • You have the option to do this. Nobody but me ever did this (go slower, I mean) Everyone seems to fall victim to "This would be a great setup for you, but for me, I need a little more power..."
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
