Intercooler Pressure Drop Test
Symptoms are saying BOOST LEAK to me ;)
Low power with current boost - tick
Knock with more boost - tick
Overheated compressor wheel - tick
Slow onset of boost?? - tick
Is 6rwhp enough of a gain for dropping the exhaust? only 2%
Edited by simpletool
  • Replies 50
It's a very free flowing exhaust...
Would a boost leak not show up when I did the pressure test? Given I took the reading from just after the turbo and then from the MAP sensor just before the manifold? If there was a boost leak, wouldn't the pressure at the turbo be greater than the pressure at the manifold, even if the pressure at the manifold was 16psi? Assuming the leak is between those two points, but where else could it be leaking from?
Which brings me to another point; Stao, if the issue here is a low reading dyno. Why did the comp wheel on the turbo I sent back to you show it had been working too hard?
Edited by Hanaldo
I think its a very low reading dyno as its reading low through out all rev ranges including the range that is on negative boost level, while the shape of curve appears to be identical to the other 3.
Also the comp wheel that sent back appears to be in pail white, while they originally has a light blue materal appearance. It means the comp wheel had very hard time pumping air through. How ever that does not affect the pre-boost power level.
well if its that recent then it's ovaboosts dyno which reads very close to Hyperdrives, How do I know? cos my car has been on both with in a week of each other. I seriously think your chasing the problems in the wrong area's. Print and overlay yours onto my sheet or mine onto yours and scan it and post it on here. That way we can compare and see possible reasons to why its not making power. I can barely see on those print outs. But it looks like its exactly the same untill about 5krpm then it slowly comes up to where mine was.
have you got prints with the boost graph. That would be very interesting to compare. I originally ran the standard wastegate, then I put on small can 14psi wastegate that Stao supplied and my car ran like shit. Then he supplied me a big can 14psi wastegate and it ran a lot better from that day onwards.
What area do yo live , PM me and you could borrow it and test how it or compare setups. (since there so damn close)
I assume you are talking about the actuator? I'm using a 20psi actuator.
I don't have a print out with boost, Ovaboosts dyno can't log boost. I'll overlay the charts I have.
Hard to concentrate right now but in my mind a boost leak won't show up in a leak test if the leak is not between the measuring points.
ie. think outside the circle.... your engine is a MASSIVE boost leak...but it doesn't show up as it is after the final measuring point. Check all the hoses and connections from the manifold...where do they end up?
Obviously it might be something else but boost leak seems very possible and relatively easy to sort out.
its easy to test for a pressure leak. all you need is a $2.00 pvc fitting from bunnings and a cricket ball. I will take a photo tonight and show you how to do it.
PS I think your missing the point about the actuator. the PSI rating is irrelavant. Its the surface area on the diagphram inside the can that makes a very large difference to how quickly it reacts.
And I find it extremly strange that a company like Ovaboost can't log the boost response. it's 1 of the most simple tools that they would use.
well it's no wonder they call themselves ovaboost. if they can't measure boost on the dyno I guess they would have some trouble setting up EBCs nicely..... jk.
I think the flow restriction isn't about a leak. Ie 30psi after turbo and 15psi on in the inlet manifold means some thing is restrictive on the way. Also noticed you are running a 600x300x100mm cooler, thats a massive cooler for this turbo, will make it laggy.
I see, I'll talk to Stao about that one.
Was a bit surprised myself about their not logging boost. My tuner told me to come back when he has his dyno up and running and he will give me a free run on the dyno so he can see what it does properly.
Lol :laugh:
Teh Lulz.
And yes there's no way to measure a boost leak because the all connected bits of pipework will have close enough to the same pressure (assuming there's no big restriction in there). You would have to measure air flow either side of the leak.
Teh Lulz.
Ah yes, good call. I knew something didn't add up about what I said. Brain no worky after uni :(
However, wouldn't a boost leak be a vacuum leak while not on boost? The car drives fine, doesn't feel like it has any vacuum leaks...
Alot of silicone can split and only open up under pressure...
If it's a boost leak, then it will account for why the comp wheel looks well over spun too.
J.
J.
Would the engine not run rich if this were the case? Suppose if it has been tuned with it then it would not...
Leak test it is then.
Yep, you're right it would be rich, but tune may be hiding it, and if that's the case you'll need a retune after..
yep i had split vac lines on my GTST for ages
only when stressed them out you could see it split
i ended up replacing them twice, same issue
finally went with thick fuel hose, problem solved
no more splits
it was always on the actuator signal vac line
unfortunatelysince my motor is out it was a little hard to get a good photo.
But as you can see remove the cross over pipe and block it with a pvc pipe end cap (use pipe clamps). remove the pipe from the pressure side of the turbo. jam a cricket ball or another PVC fitting in t. You can either pressurise the system through the bungs that you run to your waste gate or leave them all hooked up and drill a hole in 1 of the pvc fittings. I set the regulator on my air compressor to about 20-30psi. Ay that pressure it is very easy to hear a leak.
The main leak on my car was where the inter cooler had a bracket attached to the bottom. They had accidentally drilled into the core. Which I ended up blocking with araldite.
I hope that helps.
I hope that helps.
Thanks mate, I'll give it a go when I service my car in the coming week. Going to do a compression test at the same time.
Although... I don't understand how you have done it. Surely all you need is to remove the intake pipe to the turbo. Block the turbo inlet with PVC end pipe, and pump air into there? So everything works exactly how it would if the car was running?
have a look at this:
http://www.skylinesaustralia.com/forums/topic/364723-gt3076-tuning/page__view__findpost__p__5821894
This guy's made super laggy 255rwkws of a GT3076 on 20psi with adjustable cam gears and cams as well as big inlet and exhaust manifold plus bunch of other mods on hyperdrive's dyno and tune. Its either the tune's really retard or the dyno is very out.
Edited by kwickr33
http://www.skylinesa...ost__p__5821894
Doesn't look that laggy? I have seen an R34 make 280rwhp on the standard turbo at 14psi on Hyperdrives dyno. Another 34 I know of made just over 400rwhp on a HKS GTRS (unsure of boost). It's not like all cars coming out of Hyperdrive are underpowered and laggy.
 Share
    • Thanks for the reply, So i've continued playing around, and fitted the injector adaptors onto the injector, the fuel rail is not able to be mounted now as the injectors sit a bit further out. I suppose the point of the adaptors is so that the injector nozzle isn't so deep into the intake? I suppose 1mm extra on the o-ring would do it but still can't mount the rail onto the intake haha. Waiting on a reply from Aeroflow I'm sure there's something stupid that I'm missing...
    • I have a radium fuel rail on my Greddy manifold and used the supplied radium fuel injector to manifold adapters (The round green things pictured). I did always wonder if you could just go ahead and use the second lower hole like you're doing... Wouldn't thicker o-rings solve your issue?
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
    • Hi all,  I have a older model of the Greddy Front facing intake on an RB25DET NEO Head. I've bought aeroflows fuel rail and injector kit (1000cc Bosche injectors) and I'm unsure if the fitment is correct. The injector o-rings fit in the intake hole but it's not snug. I can very easily rotate the injectors even when the fuel rail is mounted. The kit also came with multiple adaptors, they dont make it any more snug and using them raises the injectors up and i cant mount the fuel rail. I hope this makes sense I've asses a few photos.    Thanks so much guys.
