My name is stuart and i have a issue with my r32gtr,
2 weeks ago the car just stoppeed and i believed either the cas or the ignition module was faulty,i borrowed both parts off a mates car and found it to be ignition moduel.
I bought a new unit and that has fixed that origional problem.I now have another
If i stand on the load pedal at 5000 rmp the car gets a flutter[like rev limit but softer]and the car still boosts fine,but if i squeeze the load pedal the car revs to 8000 rpm with out any flutter.
i have regaped plugs,cleaned and insulated coil packs[super sparks 2 years old,14,000km's]removed amm and resoldered,plus undone all elec plugs and cleaned with electronic spray.i have also looped out boost controller and checked rev limit on power fc.all sensor are working onthe car corectly.
Has any one else had similar problem and found the answer it would greatly appreciated.Thank you for your time
stuart 0409135950
https://www.sau.com.au/forums/topic/364486-r32-gtr/
I take off and nail it and at 5000 to rev limit 8000 there it is the fluffy off tone hesitaion,but the car still pulls hard,damo of sau tassy thought it may be fuel pump so i clamped off fuel return line last night still has same issue.
I also lowered the rev limit on power fc then back to the 8000 as set made no difference,thought maybe a computer glintch.
I have also disconected battery for 1 day to reset power fc.
stuart
https://www.sau.com.au/forums/topic/364486-r32-gtr/#findComment-5816511
If the coil packs and plugs dont fix,i am going to borrow a feul pump gauge and a nother power fc and amm,
all the parts i a borrowing are off a mate gtr that has same tune as mine.so i wont have to change any peramaters in fc
stuart
https://www.sau.com.au/forums/topic/364486-r32-gtr/#findComment-5817698
Stu, you go into the sensor output screen on the pfc, this is a good way to test the afms. If they put out a different voltage (noticable diff) you have a problem. Are you running an aftermarket fpr?
https://www.sau.com.au/forums/topic/364486-r32-gtr/#findComment-5817871
Hi rbnt
It looks like i have found the problem,one coil pack seems to be the issue,i have fitted my mate new units this morning and the issue has gone,so what i am going to do is keep putting min e back in one by one till i find faulty one.
A good call on the fuel pump i think i will buy a new unit as this one is 5+ years old.
A BIG THANKS TO EVERY ONE WHO HAVE GIVEN ME ASSISTANCE,AND I WILL HAVE TO UPGRADE PARTS.
STUART
https://www.sau.com.au/forums/topic/364486-r32-gtr/#findComment-5818369
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
