Can i fone a friend?thanks fo yo help.The one on the car at the moment is 400 by 260 by 65 measuered inside the end tanks.And ive been told that it would not be efficienct enough to cool inlet temps when i am in the chase for more horsepower.
How much power are you chasing? I definately don't know Intercooler size to power requierments, it all depends on the position, type and size.
The standard cooler is about half the size and can cope with about 180rwkw at the wheels so I would say that a 400 by 260 by 65 could cope with 250rwkw+.
Maybe but besides that the core has a rock crease in it.And its a big rock crease by the way and i was looking at replacing it anyway.I want to get a hybrid maybe their prices arnt to bad and they performance is exceptional?give me a day and i might be able to find out how they measure size to horsepower..... :P
Maybe but besides that the core has a rock crease in it.And its a big rock crease by the way and i was looking at replacing it anyway.I want to get a hybrid maybe their prices arnt to bad and their performance is exceptional?give me a day and i might be able to find out how they measure size to horsepower..... :P
Well i was told by con @ c&v performance...Well first i told him that i was chaseing arround 390hp @ the engine and he said ''the bigger the better''.And i said ''how big'' n he said 300 by 600 by 90.U c the bigger the drop in inlet temps the easier its gonna be to make safe power.He also said that its better when playing with the timing to have cooler inlet temps and there is less chance of detonation when running high ammounts o booosto.
So thats it the bigger the better. :alien:
what psi will you be running when the bigger fmic is fitted, as a mate put a larger core in and lost 6psi from 22psi so there may be a small drop to expect too. oh yeah he used a supra core so it was semi quality!!
Theres no big turbo yet im just thinkin about it my car is gettin a respray a kit and maybe a front mount if there is any money left.A bigger turbo is still a future mod.I think i agree with u mcboost that coola is more than ample for a 390hp @ motor in the future.
just bougth a 300 x 600 x 76 from the intercoolguy and they have pressure drop of only .2 psi (yes that is POINT 2) and the whole thing end to end is 800 x 600 x 76
he makes good stuff
:rofl::rofl: :elaugh: :spcartman
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
