Hi Guys
Haven't been here for a while, how are you guys?
Anyways, i thought i might share with you guys my second attempt at installing a car pc. Even though the first time installed ok, i kinda think i was just pushing it a bit by force mounting the lcd on the dash pocket. This time i got a double din LED and took out the head unit. Looks a lot more cleaner and i can view it under direct sunlight! I'm still using the eeepc setup and still saving up for a proper pc with dc to dc psu. At the moment i'm using a Metra double din kit, which IMO is a little tacky and the buttons are a pain to press. But that's all i could afford back then.
Major improvements over the old setup include : OBD gauges, Bluetooth, Soundblaster X-FI (made a whole lot of difference to the audio quality) direct wiring instead of cigarette lighter plug :yucky:, and the latest version of Centrafuse (3.5)
Some technical specs for those of you interested:
- Lilliput EBY701 + ByByte double din frame
- eeepc 901 , 2gb ram, 64GB kingspec ssd
- SB X-Fi Pro USB Soundard
- Blazt II OBD Scanner / reader
- Sirf III GPS dongle
Btw, my old JVC AVX-910 is now for sale. For anyone interested PM me, Price : $400 Ono. This baby can play most files no worries and have an excellent audio quality. Originally bought 2 years ago for $750.
Pics at the bottom
OLD SETUP
NEW SETUP
JVC DECK FOR SALE
Comments, suggestion ,critics are welcome ! :cheers:
Edited by dodes47
https://www.sau.com.au/forums/topic/364518-carputer-install-v-20/
I'm still using the eeepc setup and still saving up for a proper pc with dc to dc psu....
Major improvements over the old setup include : OBD gauges, ....- Blazt II OBD Scanner / reader
Hi, I have basically finished my PC (built and Installed software) and its ready to plug into and mount in my car this weekend; finally!.
One of the peripherals is the Blazt cable. My PC will be mounted in the boot, with USB cables running into the cabin connecting things like my OBD. My concern is that the USB cable run may be a bit long for the Blazt cable. Even though USB2 is defined as having a 5m maximum length, I think the blatzt cable is said have a recommendation of being no greater than 2m from the USB port; It comes with a 2m cable.
My question, how long is your distance between the Blazt cable and the PC? and have you had any problems with this length?
Hey
I pretty much have the same setup. I ran 3 5M USB extension lead from the boot to the glovebox at the front. The blazt is connected to one of the port.
No problems whatsoever. It's just as responsive as when you hook it up straight to a laptop :)
    • Had a go at the stuck crush tube this afternoon. Tried things like grips and a chain wrench first but wouldn't just twist straight off. So got to work with a drill. Started small and kept a depth stop on to make sure I didn't drill into the bolt. Made a line of drill holes all the way up and enlarged them. Then a combination of chisel and Dremel to split it all the way up. Levered the split to get oil in there and eventually it gave a bit while levering. Worked it back and forth with loads more oil till it was spinning freely, then with grips I could work it downwards and off. And no significant damage to the bolt (not by me anyway - just the 27 years of rust)
    • Well, I'm tired. I'm tired because about 4PM yesterday, before today's appointment someone immediately bought my bumper. They couldn't get it any other day as they're on the way back to NSW. So I had to do that big GTR conversion I had been planning. Unfortunately, the information on SAU about what you need and how this is done is incomplete. So what should be a simple bolt on affair, yeah, it's not. Did you know if you use all GTR items the bonnet won't close? This little manuever sent me into about 1am the night before trying to dodge a way to get it closed. I will have to revisit this in the next few days  - or maybe not, I may let a body shop figure it out. It all needs to come up and my motivation to pull the bumper off is low. It also seems to hit things in the bay where the GTT bonnet didn't. Yes I used 100% new OEM GTR items. Today, I had the joy of driving to the dyno looking like this: Given I had roughed in the fuel and given sensible but pretty conservative timing, I didn't really bet on having the car drive out any real difference than when it drove in. Sadly due to a miscommunication and laptop fun and games (and almost bricking the dongle, prayers and firmware updates indeed), I ended up using HP Tuner credits to licence the car that was already licenced. So in the end my laptop was used. It turns out my butt dyno is still well calibrated after all this time. The 325kw was on 74% Ethanol, the 313kw line was on 98. The other line is the 'before' line which was 281kw. While the numbers are pretty low, they're pretty in line with what you'd expect. Even if US dynos bump the whole result up about 50KW, gaining 10-15% is similar gains.  The curve of the cam is pretty much spot on with what was discussed as well. All this said, it still feels bad to not see the number you secretly want to see. Even if the car drove great beforehand, and I knew pretty confidently the car would drive out much the same way it drove in due to the nature of a wellish dialled in LS1 not gaining much if anything at all from being tuned from where it was. As expected, the car isn't particularly sensitive to running it at anywhere between 12.0 and 13.0 - And the initial timing at 20deg and 12.0 made 308KW. So 3 degrees of timing, and leaning it out to 12.7 for 5kw, anything above stopped giving any benefit until E85 (which has an additional 2 deg as before). Car itself behaved entirely fine. I found out that 100C = 1.15V! IAT at about 7pm was 19C. I might mess with the bonnet mounting.. but given the REO NEEDS TO BE CHOPPED TO FIT A GTR BAR this is possibly something I may leave gathering (more) dust until it returns to paint jail.
    • It sounds farrrrrrr too cold at your place Duncan... Here I was thinking our 10 degrees overnight is getting cold...
    • oh yeah, reminded this morning....bin lids frozen shut too
    • In my case not, because of total reno. But yeah.
