Hi Guys,
I havern't seen many posts outlining the results of removing the AAC. Obviously to make up for it missing you would need to adjust the Throttle body to allow the right amount of air in idle. I know it is silly for it to be removed as it helps out when Aircon and power steering is been used + stacks of other things. Personally I am keeping mine on. But it would be nice seeing if people have done it and can provide their knowledge to anyone that decides to remove it.
The Main questions I would ask if I was doing it is.
1. When adjusting the TPS would you reset the postion to 0 once you find the perfect idle or would you allow the ECU to relise there is some throttle been put down.
2. Would there be any problems with a BOV setup as creating a system like this you will never have full throttle closure.
3. Has any one experienced problems when going into full lock or turning on the air con.
Edited by simons987
https://www.sau.com.au/forums/topic/364525-removing-aac-has-anyone-done-it/
The Microtech would have its own Idle control, I wonder if anyone has run it on a stock ecu or with Nistune????? Do you still have your TPS on and how is it setup? Is it configured to identify there is idle or has it been reset??
Edited by simons987
mine is not connected but thats due to the car not having aircon at all however im running a microtech also
AAC is still needed without aircon
Why would you want to take the AAC off? It just creates headaches doing so
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
