No, it's not.
But it will wield greater results.
If you want to go with a highflow, maybe talk to Stao at Hypergear.
If you don't need a ball bearing core, he can high flow the stock M35 turbo for around $800.
Nice work too!
(just exercise caution as he really pushes for a GT3076 core!!)
for me it wouldve been much cheaper :(
i'de get on a GT3071 if I had to do it all again.
Agreed, you can all get fudged. lol.
The issue wasnt the fuel pump but the lines being too small so you will need to upgrade the lines for anything over 300awkw on e85. Petrol, perhaps 350?
So run BP98 at 22 PSI and crack 300AWKW's......no fuel system upgrade then!........even better run 330AWKW's at 20 PSI on BP98 with shorter diff ratio's!banana.gif
OH and take some load off the gearbox at the same time.....you have you E85....I have my gears!!!
Oh and standard housing with GT30/71 internal's and BB set > GTX!!!!...lolz
Edited by Jetwreck
oh......worship.gif...work's well with the VQ25DET! and you know that how?
Is that what you said initially?
Didn't think it was.
A 3071 equivalent sized GTX will flow more considerably more and spool faster than your GT3071 high flow.
... although having said that, the A/R of Scott's turbo might incite a fair deal of lag :P
there it is....know one know's really yet do they?..........I was trying to stir Scott.....you stuffed it up for me!biggrin.gif
Glad to be of assistance :nyaanyaa:
No, no-one really knows... but I'm sure if he got a 5000rpm stall and an Fcon mapped to 10,000rpm he'd be able to use it effectively.
Funny enough, since unplugging the throttle body, I have more throttle opening at stall, from 26% to 36%. I don't get it...
I tightened the return line fitting as it was leaking a bit after the drive. I will have to monitor it tomorrow as the engine bay stinks of e85. Time for a smoke. >_<
could the throttle map take values and depend on the AFM input? if thats being modified by the emanage, the ECU may be thinking there isnt as much airflow and its safe to open the throttle further?
