also have a tanabe? r33/r34/stagea under gearbox brace. gives added chassis strength, good mod for those after handling. bolts up under gearbox, 99% of stagea have the holes already as it were a factory 260rs standard feature, (mine is much bigger than the 260 one)
$200
  • Replies 58
bit of an update
na grill sold
short shifter sold
eye brows sold
rear wiper sold
momo will be going on sat arvo
decat and dump is going to brentwagon when i get them off
brake look to be sold also
pod, intake, profec b, bov, gauge and indicators also are on hold for a member for 2 WEEKS
rear cargo and net is kinda on hold... but if someone waves cash as me ill take it 1st.
have a stong lead on the turbo, ecu
chad i am keen to swap headlights with you please pm me regarding this
Edited by chef_stagea
HKS 25/35 turbo kit (direct bolt up to rb20, 25 and neo 25... uses stock dump, mani etc etc..) i have had braided water in and out made, stock oil in and dump. the turbo is 15,000ks old from new and is in IMMACULATE condition. $1600 FIRM with lines
z32 afm with pig tail loom $200 or $150 with your rb25 neo afm and loom
seimens deka 660cc injectors (black in colour and are not visible at all) these come with my stock inj loom with the req plugs soldered on, fuel rail spacers. these went in new when i rebuilt my engine, and have been used for about 4000ks of driving, they are not big enough to mess with your idle, but are big enough to push out much more than the 25 will ever hold. (note: these are only for s2 (rb25neo) $500 with your stock inj loom only
white dash backing bits, sticks to your stock one over the top, back lights up red, pretty kool i spose. $70
-3 inch cat back, 1 mid muffler, and rear muffler, great rear pipe, will have to get pics $300
SA buyers only (at this stage)
nisstune ECU (worked with my car as auto and manual) as we know.. the best stealth ecu out by far! paired with my mods it was amazing!... $300 with your ecu (will need to do some research as to what ecu i really need... coz im manual now but may still need an auto ecu... and believe there may be a few) i will give this to you and once your tuned... drop off your stocker
tein type CS coilovers (suit s1 and 2 auto only) these are in mint condition and are height and 32-point dampener adj, they come with c-spanners, rebound tool and some stickers from new, and manuals,
$900 with my adj ISC toe and camber arms (10,000ks old)
s2 Xenon headlights, all factory set up plug and play, mine are in perfect condition, $300 firm no ifs or buts
Advan intercooler, no bent fins, fits up to stock set up, not return flow tho.... bolts up to chassis rails, quality is 2nd to none, ive used these light tinney chinese shit b4, and i couldnt believe i didnt go strait for the real deal! no cutting o the front side of the reo bar, just the underside so it sits flat, im sure i could actualy mount without any trim if u took time to play with it. $500
rear cargo blind in black, mint bar the drivers strut tower clip has a small crack, doesnt effect performance. $100
SA WHITE S1 & 2 buyers ONLY
my rear lights have the small covers on them (insides and top bits) if some one wants them, they can come swap me there tail lights thats are in mint condition $50
leather seats SA ONLY $450 plus your seats (s2 only)
swaybars sold
cargo net sold
rear wiper sold
front eyelids sold
momo sold
pod sold
intake sold
shifter sold
profec b sold
indicators sold
bov sold
33 brakes sold
boost gauge sold
decat sold
dump pipe sold
COIL OVERS $800 PICKED UP IN ADELAIDE!!!!
    • I have an old R32 in the shed that hasnt moved much in the last few years and probably should see the light of day. At one point I had a Nismo 1.5 centre put in the rear diff. It is a clunky nightmare POS of a thing on a good day. To make it less painful the initial torque setting has been put on the minimum (7.0kgf-m, mid is 9.5, high is 14) and the oil changed out to something more slippery. But it is still awful and ruins the vibe of the thing. So my questions are: Given I have the original parts sitting in a box somewhere would it be better to rebuild the thing again, reverting to more purity? Is there a standard kit or do you just go and replace the friction plates etc and shim it the way you like it. How much initial torque does the standard R32 rear diff have? Or does the Nismo disc kit offer a better solution - the caveat being the initial torque for both options appears to be higher than the clunky 1.5 way. There appear to be two Nismo disc kits: 3843S-RS520 for 8kgf-m. 3843S-RS521 for 12kgf-m.
    • It is not a dual mass flywheel, so you will get some gear noise on a BNR34 unless you deviate from the OEM fluid spec and run a thick gear oil like what Nismo recommended for a while. Unfortunately I have never weighed the flywheel by itself prior to installation but it is not that light. It's probably an 8-9 kg flywheel. OEM BNR34 dual mass flywheel is like 14 kg which is kind of hilariously heavy.
    • Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards. Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought. So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate. I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate. I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf. Fuel tank foam as extra cam cover baffling?
    • The incoming weather event seems to be affecting people in weird ways....🤣 And no, whilst there is some fancy engineering going on, I have no real interest in anything rotary really I had a Capella in the 90's, the rotary engine is way to temperamental, and extremely thirsty for my liking  If I won lotto and wanted to waste a ton of cash, a boosted K-swap would be what I would look at, until then, the N/A MZR2.5 will be at home in the engine bay of the NC A build like this, just without the idiotic street pulls and skids would be interesting to waste a huge amount of money on https://youtu.be/EgqAoVtUD1E?si=n3_umivrUPP8C9Cs
    • Now we're getting somewhere. All we need is a fractional rotor system so we can also have the RX3 and 5 back, and the world will be right again.
