TD06H-25G Turbo Rebuilt by GCG in September last year, only used to test the car to find out if engine was still blowing smoke. Turns out it was and now have a whole new engine in the car.
Comes with external wastegate, and Manifold for RB25DET.
Spools quickly, big power.
May seperate if Items do not sell.
$3000
Located in Bundoora (Melbourne)
Pick up preffered
Will ship at buyers cost.
Paul Davis
[email protected]
0431874557 (please note that I work 8pm - 4am and will be asleep during the day... but leave a voicemail or sms and I will get back to you asap)
https://www.sau.com.au/forums/topic/364548-td06h-25g-with-parts-for-rb25det/
  • 3 weeks later...
  • 4 weeks later...
Hey mate,
A few questions:
-Does this fit an R33
-Are these items from a genuine Trust turbo kit? ie is the turbo and manifold trust branded?
-Do you have water/oil lines
-Do you have any other parts from the kit such as the dump and intake piping?
-When did it come on boost and full boost on your RB25?
Thanks!
yes, fits r33.
Only branding I can see on it is mitsubishi symbols. But I do know that GCG rebuilt it to Trust original specs.
Oil & water lines are a no.
Intake pipe is included, dump pipe can be included also but it is only a few inches of pipe, not a full dump pipe.
In terms of boost, It has been a while but it did come on fairly quickly, lag wasn't noticable.
Rear housing, I'm unsure, if you can tell me how to find this, I'll let you know.
Also for pricing comparison, paid $4k for the kit, $1.5k for rebuild. Only asking $2.1k...
Cheers
The compressor side looks larger than the standard trust housing (And the trust housing has Trust logo etc..) although it could be due to the polishing.. Do you have any details about the compressor housing?
Thanks again
The company I bought it off sold it to me as a T76, but when I got it rebuilt, GCG paperwork all said TD06H-25G, so I assumed that they were correct. To be honest, I don't know a lot about turbos, so if there is a way to find out any details you're after just let me know and I'll do my best.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
