Hi guys!
Sorry i'm a bit strange and this is also my first post. Hopefully i will get some serious helps from you guys!
I currently own a R33 GTST and it was running like a dream! About 2 days ago i tried put a bigger battery on. Then i realised that i put the wrong way around positive and negative terminals. However it didn't affect to the car as all the electricals are still working, no fuse blew off. Straight away i started up the car and it only cranks... won't start at all.
I checked the fuel system and it's fine, injectors click click.
We tried to push the car straight down from the top of the hill, then put on first gear and rev it up a bit then it suddently start up and idle fine! But if i turn off the key there is no way to start it back on even it cranks.
From what i've tried i can feel the fuel pump working once i turn the key on, haven't check out the spark yet BUT if i roll it, it will start up so i guess there is nothing wrong with spark.
There are some lights on the speedo indicate fuel and water!
I will reset the ECU tonight and see what will happen tomorrow.
Please suggest me what to do! I really stuck...
Thanks guys!
Edited by r33 rb30dett
I'd be 99% sure it'd be a fuse, as it's the "first defence" from the terminals.
Did you check all three fue boxes?
-Under the driver side dash
-Next to the battery
-The big black box in the engine bay
It will def be a fuse. You cant put the battery terminals on backwards without blowing something lol. Did the bit spark not give it away? :P
My guess will be one of the "Engine Control" 10A ones under the dash.
mate i checked all the fuses and they are fine!
anyways i will be getting a consult cable from a friend, then do some testing with the computer and hopefully it will tell
Its a long shot but it could possibly be the ignition/ecu relay next to the ecu (big blue ones)
When i soldered a couple of wires without disconnecting the battery i stuffed one of them, i swapped them over and all was good.
when you turn the key to ign you should hear two clicks from the passenger side.
just a possibility ?
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
