Hi guys!
Sorry i'm a bit strange and this is also my first post. Hopefully i will get some serious helps from you guys!
I currently own a R33 GTST and it was running like a dream! About 2 days ago i tried put a bigger battery on. Then i realised that i put the wrong way around positive and negative terminals. However it didn't affect to the car as all the electricals are still working, no fuse blew off. Straight away i started up the car and it only cranks... won't start at all.
I checked the fuel system and it's fine, injectors click click.
We tried to push the car straight down from the top of the hill, then put on first gear and rev it up a bit then it suddently start up and idle fine! But if i turn off the key there is no way to start it back on even it cranks.
From what i've tried i can feel the fuel pump working once i turn the key on, haven't check out the spark yet BUT if i roll it, it will start up so i guess there is nothing wrong with spark.
There are some lights on the speedo indicate fuel and water!
I will reset the ECU tonight and see what will happen tomorrow.
Please suggest me what to do! I really stuck...
Thanks guys!
Edited by r33 rb30dett
I'd be 99% sure it'd be a fuse, as it's the "first defence" from the terminals.
Did you check all three fue boxes?
-Under the driver side dash
-Next to the battery
-The big black box in the engine bay
It will def be a fuse. You cant put the battery terminals on backwards without blowing something lol. Did the bit spark not give it away? :P
My guess will be one of the "Engine Control" 10A ones under the dash.
mate i checked all the fuses and they are fine!
anyways i will be getting a consult cable from a friend, then do some testing with the computer and hopefully it will tell
Its a long shot but it could possibly be the ignition/ecu relay next to the ecu (big blue ones)
When i soldered a couple of wires without disconnecting the battery i stuffed one of them, i swapped them over and all was good.
when you turn the key to ign you should hear two clicks from the passenger side.
just a possibility ?
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
