Hi guys, ive got an r32 gts4 with an r32 gtr rear diff and standard front diff. The standard rear diff was driven by the previous owner without enough oil, so i know that diff is no good, it really grinds if you try to drive with that diff in. I have an r32 rear diff to get me by until I can replace with another gts4 diff. I was wondering if the crown and pinion gear ? unsure if they are the two parts, but are they interchangable with the gtr's crown and pinion gear?
https://www.sau.com.au/forums/topic/364622-r32-gts-4-rear-diff/
There is an issue with running the GTS4 and GTR diffs, they have different ratios.
I know there is an issue, thats why I am trying to get the gts4 diff back. I am currently RWD.
Is the gtr diff mechanical and the gts4 diff viscous? Are the crown and pinion gears interchangeable anyway?
Is the gtr diff mechanical and the gts4 diff viscous? Are the crown and pinion gears interchangeable anyway? I dont want to remove my diff only to find out they wont match, do I need the crown gear only, or the crown gear and the other gear which turns the crown gear?
You'll have to check the front diff ratio. The GTR is 4.1:1 so the previous owner should have changed the front diff to suit (unless he is available to be asked). I think the GTS4 is 4.3:1
Yeah, I know the front diff is the standard gts-4 diff, 4.375, but i cant run 4wd cos of the rear diff issue, i have the standard diff out of the car, i wanted to swap the gears over to the working gtr diff i currently have on the car, i was wondering if the gears are directly interchangable, even though one is viscous, one is mechanical.
You will be able to swap the GTS4 gears (crown wheel and pinion) into the GT-R diff. But you must do BOTH - you can't just swap the crown wheel OR the pinion.
There wil not be any problem with the GT-R centre being mechanical LSD and the GTS4 being a viscous LSD. In fact, you are probably better off with the GT-R's mechanical centre,
Copy that, I changed my rear diff gears on friday, from 4.11 to 4.375, no problems at all!
Much better to drive, 3rd gear is way closer to 2nd now and the whole car fells much more responsive!! Win Win
I asked a diff place in western Sydney if they could check the condition of the GTS4 diff on Thursday, as i know it had been run without enough oil which caused the grinding noise. The guy said
everything is faulty, crown, pinion, bearings, all without even looking at it. It hadn't been run with no oil, where is definitely an issue because it is grinding but I was hoping maybe
the bearing has failed, and the crown and pinion would be OK. He would not even open it to have a look, is there anyone who could possible help me diagnose what parts are faulty? I know the
bearing is definitely gone, but I am hoping the gears are OK, it wasn't driven around for long after the noise occured so I am hoping no shavings damaged anything else. Anyone help?
Must be Superman (has X-ray vision) if he can tell the condition without opening the unit!
You just need to take off the rear cover plate to inspect the innards. Then find another diff specialist to confirm or deny the condition of the crown wheel and pinion - these are the only bits that need to be in OK condition.
  • 2 months later...
OK, so me and a mate have finally taken the gts4 diff apart, I can confirm that there is physical damage to the bearings and cage which sit at the rear of the crown gear (where the drive shaft meets the diff). There seems to be no damage to the main gears, with no scoring on any of the main contact surfaces, and little to no wear on any moving part. The crown gear seems to be seated in the housing quite well and blunt force does not seem to dislodge the casing. Also, I cannot see how I can remove the faulty bearing cage. From what I can tell only the one bearing cage at the very front of the pinion is faulty.
So three questions, how do I remove the pinion gear from the diff housing? How do I remove the bearing cage for replacement? And where could I get a replacement bearing cage from?
I also have that gtr diff on the car currently which I could possible salvage parts from, but I would rather get a cheap gts-t diff or something for the parts I require, so if the bearings are the same part that would be cool.
Thanks for the input
From memory you take out the crownwheel and then knock the pinion in but before you take to it with a sledgehammer get someone to confrim that!
Here's a bit of a long winded how to (I'm a bit rougher myself) - you can put it back together yourself but ideally its properly set up by a diff shop or you could just get a complete diff and swap it over:
http://www2.dana.com/pdf/AXSM-0053.pdf
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....馃ぃ) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
    • R33 with RB26 seems to go off of learned voltage for idle. Seemed like whatever the baseline voltage was once ECU first gains power will be the idle voltage. With ignition on unplug/replugging the TPS would relearn the idle TPS voltage.
    • Have you confirmed the 2 pin coolant temp sensor on the motor is working properly? I've had a very similar issue when I forgot to plug mine back in many years ago.
    • Ok interesting i guess ill wait till using a manual gauge before making assumptions.
