Hi guys, ive got an r32 gts4 with an r32 gtr rear diff and standard front diff. The standard rear diff was driven by the previous owner without enough oil, so i know that diff is no good, it really grinds if you try to drive with that diff in. I have an r32 rear diff to get me by until I can replace with another gts4 diff. I was wondering if the crown and pinion gear ? unsure if they are the two parts, but are they interchangable with the gtr's crown and pinion gear?
https://www.sau.com.au/forums/topic/364622-r32-gts-4-rear-diff/
There is an issue with running the GTS4 and GTR diffs, they have different ratios.
I know there is an issue, thats why I am trying to get the gts4 diff back. I am currently RWD.
Is the gtr diff mechanical and the gts4 diff viscous? Are the crown and pinion gears interchangeable anyway?
Is the gtr diff mechanical and the gts4 diff viscous? Are the crown and pinion gears interchangeable anyway? I dont want to remove my diff only to find out they wont match, do I need the crown gear only, or the crown gear and the other gear which turns the crown gear?
You'll have to check the front diff ratio. The GTR is 4.1:1 so the previous owner should have changed the front diff to suit (unless he is available to be asked). I think the GTS4 is 4.3:1
Yeah, I know the front diff is the standard gts-4 diff, 4.375, but i cant run 4wd cos of the rear diff issue, i have the standard diff out of the car, i wanted to swap the gears over to the working gtr diff i currently have on the car, i was wondering if the gears are directly interchangable, even though one is viscous, one is mechanical.
You will be able to swap the GTS4 gears (crown wheel and pinion) into the GT-R diff. But you must do BOTH - you can't just swap the crown wheel OR the pinion.
There wil not be any problem with the GT-R centre being mechanical LSD and the GTS4 being a viscous LSD. In fact, you are probably better off with the GT-R's mechanical centre,
Copy that, I changed my rear diff gears on friday, from 4.11 to 4.375, no problems at all!
Much better to drive, 3rd gear is way closer to 2nd now and the whole car fells much more responsive!! Win Win
I asked a diff place in western Sydney if they could check the condition of the GTS4 diff on Thursday, as i know it had been run without enough oil which caused the grinding noise. The guy said
everything is faulty, crown, pinion, bearings, all without even looking at it. It hadn't been run with no oil, where is definitely an issue because it is grinding but I was hoping maybe
the bearing has failed, and the crown and pinion would be OK. He would not even open it to have a look, is there anyone who could possible help me diagnose what parts are faulty? I know the
bearing is definitely gone, but I am hoping the gears are OK, it wasn't driven around for long after the noise occured so I am hoping no shavings damaged anything else. Anyone help?
Must be Superman (has X-ray vision) if he can tell the condition without opening the unit!
You just need to take off the rear cover plate to inspect the innards. Then find another diff specialist to confirm or deny the condition of the crown wheel and pinion - these are the only bits that need to be in OK condition.
  • 2 months later...
OK, so me and a mate have finally taken the gts4 diff apart, I can confirm that there is physical damage to the bearings and cage which sit at the rear of the crown gear (where the drive shaft meets the diff). There seems to be no damage to the main gears, with no scoring on any of the main contact surfaces, and little to no wear on any moving part. The crown gear seems to be seated in the housing quite well and blunt force does not seem to dislodge the casing. Also, I cannot see how I can remove the faulty bearing cage. From what I can tell only the one bearing cage at the very front of the pinion is faulty.
So three questions, how do I remove the pinion gear from the diff housing? How do I remove the bearing cage for replacement? And where could I get a replacement bearing cage from?
I also have that gtr diff on the car currently which I could possible salvage parts from, but I would rather get a cheap gts-t diff or something for the parts I require, so if the bearings are the same part that would be cool.
Thanks for the input
From memory you take out the crownwheel and then knock the pinion in but before you take to it with a sledgehammer get someone to confrim that!
Here's a bit of a long winded how to (I'm a bit rougher myself) - you can put it back together yourself but ideally its properly set up by a diff shop or you could just get a complete diff and swap it over:
http://www2.dana.com/pdf/AXSM-0053.pdf
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
