  • Replies 62
This does my head in. The tests done and the symptoms reported (such as fuel still flooding cylinders with the fuel rail and injectors up off the engine) only supports the single theory - which is that the fuel is going in through the inlet manifold. Which means straight through the reg and down the vacuum hose.
Pretty much nothing else fits. The fact that a second reg did the same thing does not negate the theory. Try again. This time, close/clamp/block the signal line from the reg to the plenum, or even better, leave it open and point it at your face (so you can see the fuel coming out at you at high speed).
  • 6 months later...
Straight down the reg and out the vacuum hose... so the vacuum hose from the FPR is still connected? If so, i've heard of FPR's breaking their vacuum plate and letting fuel flow straight through it into the vacuum hose. Disconnect or clamp it off?
I read this first because my car wouldn't start a couple of days ago after parking it in the morning. I've since deduced that my fuel pump has died and I have *no* fuel being squirted into the mix.
    • I believe Unimog is the only vehicle that has it (from the manufacturer). I haven't seen aftermarket permanently connected kits, but I haven't looked either.
    • Ha ha ha, can't overthink when exhausted... Oh how I wish I had that power! I can be absolutely dead set shot, and my brain will still go "we need a good 3 or 4 hours to just think about everything and anything before you may sleep... My biggest thing is making sure I give myself enough sleep. I don't operate on even 7 hours of sleep! I attempt to give my body 9.5hours sleep a night to be able to function. I don't sleep the whole 9.5, but I need to make sure I offer a big window. I also take a single supplement, which is to help with long term health, and fighting inflammation, and I notice it helps massively. Especially me sleeping, and just less "achey" in the body. Have also kicked sugar, and gluten. A majority of people with ADHD don't go well with gluten. It causes a really interesting natural opioid overdose in the brain, which causes bodily issues and sensory issues.
    • Yeah that's what I meant, permanently connected not manual
    • Yep. But typically that's just run a hose down to the tyre while stationary.   Oh and the Unimog will automatically air up and air down tyres from the onboard computer for you too.
    • There was a good video somewhere, maybe Kurzgesagt that linked physical activity to ADHD/Anxiety/Insomnia etc. Basically the body WILL spend energy doing something if you don't spend it doing anything physical. It isn't fun, but I personally have noticed I've never been overthinky, or unable to sleep if I'm physically exhausted from doing a lot. The musings around it seem to indicate that this is one of the reasons/mechanism that physical activity improves mental health/wellbeing etc, by more or less not using that 'extra' energy to overthink, be anxious, inflammation, etc. There's also the fact that every obnoxious exerciser ever says it's great and helps which is extremely annoying. Like people who say the same thing about travel being the best thing ever. I mean, they clearly are, but blah. I started doing a LITTLE myself (think 3x15min per week) and honestly did notice the benefits, aiming at life quality when older. Which is sooner than you think. Getting something into your routine that you can actually make a routine has helped me at least. This post brought to you by procrastination between sets.
