  • Replies 53
They system is physically different in terms of the actual mechanics so it would probably not work.
If there was a schematic for the system you could compare.
Things like extra sensors, inputs and stuff might exist?
There is a schematic of the R32 unit in the manual that everyone has a copy of. Never seen one off an R33.
At the end of the day you have the usual range of sensor inputs - wheel speed, accelerometers, brake input, TPS and that is it.
attessa schematic.pdf
the best and quickest way is to find the control module on yahoo jp auctions for 32 33 34
check the photos and compare differences
youll soon see if the loom connector is different
im sure you guys arent the first in the world to try it
otherwise everyone who had BNR32 would buy BCNR33/BNR34 attessa as the first mod to increase handling
Yeah, good find paul, but I would still be interested in seeing what is involved in putting the newer system in a 32.
If we can write up a list of what we need I will look into tracking some stuff down, because I know atleast one other person then myself who would be very interested in this.
But that will not help with the sample rate will it ?
was talking of completely transplanting the whole system from a 33/34 into my 32 and making all the sensors work.
Not sure.
R32/33/34 attesa is the same mechanically. 34 transfer case is a little different from memory in that it fits to the getrag box but I'd have to look at one again to be sure. but they are still basically the same thing. you can transplant the ecu etc from a 34 into a 32 just need to know the right pinouts etc to get it working. I've seen it done in japan in a 32 with 34 attesa and 34 abs too.
if you want to go the whole hog you can buy a 34 getrag and transfer case, put that in, then get all the sensors and ecu's needed to run it. might as well go 34 ABS while you're at it and maybe add a 34 engine ecu and cas etc so you can basically have 34 driveline in a 32. then you could easily add the MFD too. would be nice to have 34 ABS/ATTESA and MFD in a 32.
Nah I have done the re shimming thing & done the controller that fiddles with the lateral gee input for more front bias.
But going from 4Hz to 100Hz must make the system more reactive & more repeatable. I mean, at only 100kmh you are moving about 7 metres every quarter of a second. So it is not like the R32 system is on the ball.
How do we get hold of the 33 pinouts? Anyone got a manual?
f**k yeah !
I remember reading about a workshop that basically put all the goodies from the 34 into the 32.
I think it would be quite a large improvement.
As for manuals, I'm capped at the moment until midnight, but I will track one down once I can load web pages again :/
  • 10 months later...
hi i know this is a old post but i am fitting a r34 gtr motor to my s1 stagea and would like some info.
i am prob going to need to run the 34 ecu and engine loom do u know if they are locked and would i have any probs with fitting it to the stagea?
and is there any other way of telling i have a 34R motor besides the the cas , turbos , color of the rocket covers or injectors?
and is there some where i can check the engine numb with out the rest of the car info?
The R34 gtr ecu's are key coded, so you don't want to go down that path unless you are using a power fc or other after market engine management. Your better off with an R32/R33 ecu and then reversing the pin order on the CAS, keeping an R34 CAS.
The engine block number will be able to shed some more light on the engine type.
R33 numbers started at RB26-0479xx
R34 numbers started at RB26-069xxx
http://webbersrbguide.com/index.php?option=com_content&view=article&id=47:engine-number-register&catid=42:engine-number-registers&Itemid=2
    • I'm seeing torque specs all over the place for the OUTER tie rod, but none for the INNER tie rod, where it connects to the steering rack. Even in videos, people are just tightening em up as much as they can with a wrench and that's it. Anything tightened down without torque makes me nervous. Anyone know what the spec is for it?
    • Hope you had a great time here in our tiny country.   The JDM scene we have here is quite small, it's mostly BMW, Volkswagen with burble tunes haha. But the few JDM cars we do have in the scene are pretty nice. Some of my friends drive cool s14's too. Both built engines, red one makes abt 500, blue one abt 400 i think?
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
