I listed this up recently but have dropped the price a lot (read: $3000!).
Previous owner was a mature lady owner who imported it and who owned it for around 5 years.
Here are the details:
Interior:
the interior is very clean with only a single slight mark on the rear seat that is almost unnoticeable
Power windows
power steering
power mirrors which fold back into the car so that they dont get damaged
air con only needs regassing
kenwood equalizer and cassette player with a 10 cd stacker in the boot
climate control
blitz turbo timer
fully electric sunroof with open/close and tilt up and down feature
Engine:
2.0L six cylinder turbo
automatic
144,000 klms with a full log book service history (serviced every 5000kmls)
mechanically a1, drives wonderfully
cat back 3" sports exhaust with a large tip, but everything else is stock
4 brand new brake pads
Exterior:
The paint is in very good condition with just the usual little scratches and marks because it is a daily driver, but overall, it is very good paint.
Red/maroon
bodykit with a front bar, side skirts and a rear spoiler (i think the rear bar is stock)
driving lights
17" mags with a chrome deep dish (look really good)
4 near new 235 tyres on each corner
camber adjustment kit so that you dont chew through the tyres
window tint
slimline weather shields that stop the rain coming in the car with the windows down
Now the couple of bad things:
it has a small (5 cent piece size) piece of rust near the back window. Very small though.
There is a little rust on the edge of the sunroof because the rubber just doesn't seal perfectly against the opposite surface. The sunroof does not leak whatsoever though.
The car does not like cold mornings! (like most cars!) It always will start though it just sometimes takes a couple of tries. I think it would just need a tune up, because it idles and runs absolutely perfectly.
This really is a great car, that runs wonderfully and without a problem, but it most be sold!
it has 6 months qld rego on the car at the moment but the car will be sold with 12 months nsw rego on it. I am putting 12 months NSW rego on it this week, so if any QLD people are interested, you better let me know before i put NSW rego on it to save you the trouble!
The car is located in Murwillumbah which is on the east coast about 30 mins south of the qld/nsw border or about 1 and 1/2 hours south of brisbane.
Price: best offer above $15,500 will sell the car!
Thanks guys
https://www.sau.com.au/forums/topic/36476-fs-r32-skyline-must-sell/
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
