I listed this up recently but have dropped the price a lot (read: $3000!).
Previous owner was a mature lady owner who imported it and who owned it for around 5 years.
Here are the details:
Interior:
the interior is very clean with only a single slight mark on the rear seat that is almost unnoticeable
Power windows
power steering
power mirrors which fold back into the car so that they dont get damaged
air con only needs regassing
kenwood equalizer and cassette player with a 10 cd stacker in the boot
climate control
blitz turbo timer
fully electric sunroof with open/close and tilt up and down feature
Engine:
2.0L six cylinder turbo
automatic
144,000 klms with a full log book service history (serviced every 5000kmls)
mechanically a1, drives wonderfully
cat back 3" sports exhaust with a large tip, but everything else is stock
4 brand new brake pads
Exterior:
The paint is in very good condition with just the usual little scratches and marks because it is a daily driver, but overall, it is very good paint.
Red/maroon
bodykit with a front bar, side skirts and a rear spoiler (i think the rear bar is stock)
driving lights
17" mags with a chrome deep dish (look really good)
4 near new 235 tyres on each corner
camber adjustment kit so that you dont chew through the tyres
window tint
slimline weather shields that stop the rain coming in the car with the windows down
Now the couple of bad things:
it has a small (5 cent piece size) piece of rust near the back window. Very small though.
There is a little rust on the edge of the sunroof because the rubber just doesn't seal perfectly against the opposite surface. The sunroof does not leak whatsoever though.
The car does not like cold mornings! (like most cars!) It always will start though it just sometimes takes a couple of tries. I think it would just need a tune up, because it idles and runs absolutely perfectly.
This really is a great car, that runs wonderfully and without a problem, but it most be sold!
it has 6 months qld rego on the car at the moment but the car will be sold with 12 months nsw rego on it. I am putting 12 months NSW rego on it this week, so if any QLD people are interested, you better let me know before i put NSW rego on it to save you the trouble!
The car is located in Murwillumbah which is on the east coast about 30 mins south of the qld/nsw border or about 1 and 1/2 hours south of brisbane.
Price: best offer above $15,500 will sell the car!
Thanks guys
https://www.sau.com.au/forums/topic/36476-fs-r32-skyline-must-sell/
    • I don't like "actual computers" for in car use. They take time to boot up, have OS annoyances, and so on. Arduinos etc are ready to go a few seconds after power on, don't mind being agressively powere cycled, because everything is non-volatile, don't mind being shaken and stirred.
    • As Fred would tell us, it's all about interpreting the rules. It's not a water sprayer, it's a water mister... But everything else you've said, 100%! Even a raspberry Pi would be great, use HDMI out for a display, and add a raspberry Pi CANBus hat to read values out from the ECU.
    • Being a race car, and being in the era of the Arduino, one would think it would take little effort to build a controller to do the spraying based on a real physical measurment. Waaaaay back in the dim dark AS days, JE "designed" (as in, he had help) a microcontroller based intercooler spray system. It watched the difference between a temp sensor stuck on the core and one in the free air in front of the cooler, and if the temperature difference exceeded a (settable) threshold, it would activate the sprays. Thus, it only ran water when there was an actual need for water. If you stop to think about the actual physical things that are going on in that stack of coolers, there's probably at least a couple of triggering conditions one could come up with, and one could probably even run one pump with more than one solenoid valve, to allow water to be placed where it is needed, or at all points at once (if it is needed at all points). We're in the age of science baby. But.... I suspect that intercooler water sprays are on the forbidden list in most circuit classes, no? So only good for Targa type stuff?
    • I'll just leave this with, holy shit, those cars at work are awesome, and this will look wicked!
    • Could you modify this duct so instead it pushes the extra air through the radiator too and not down and out? For temps, I know it's not the greatest idea, but as a bit of a last resort, you could use a very intermittent misting spray onto the front of the coolers/rad. You don't want to be soaking them such that water is dripping off, but a small most on/off so that the water evaporates. That point of it constantly evaporating, rather than being soaked in water, will pull a LOT of heat out of the cooler. I'm literally thinking just the little mist sprayers for a garden from Bunnings. Being in a low humidity climate it will help even more! The other trick if you want to be ghetto is some shade cloth hung in the opening, and keep it wet. Pretty much now it's acting like an evap cooler on a house, but cooling the air you need to use to cool the radiator...   On a topic to think about too though, when air enters through the bumper, is it all nicely ducted from the edges of that opening back at a nice angle, or is it like most cars, and the edge of the opening just stops, and suddenly it's wayyy wider behind that? If it does the later, get it shrouded out at nice angles. When that opening changes too rapidly, it can actually cause a high pressure zone between the front bar and radiator, and limit air flow into that area, which means less air for cooling, as it effectively stalls the air, AND adds to drag...
