As topic states stripping a 93/94 Series 1 R322 GTST. Car is pretty much stock as apart from a manual bleed valve.
- RB25DET (122kms) $1250
- R33 Manual box $1400
- R33 brakes (front and rear) $700 (calipers and rotors)
- Rolling shell? $3000? (no dents etc....few random scratches etc as you would expect
all interior parts, seats, Factory airbox, factory exhaust etc etc
Other stuff
- R32 GTR Rims $700 (set of 4)
- 18" 5 spokes $700 (with federals 2good and 2 shagged)
- S13 twin 2.5" exhaust $150 (brand new) diff section back
- Microtech LT12S $850 (brand new)
- R32 Rear Parcel shelf $20 (no grills and unbroken)
PM me for more information and pics will be up shortly or as required..........................
https://www.sau.com.au/forums/topic/364786-stripping-r33-gtst-other-stuff/
Topic says its a 33?
If its a 33 how much for the steering colum surround plastics and the 2 plugs from the climate control unit with as much wire as possible?
hey mate chasing drivers side window switch, series one 11 pin not 12 where it plugs in, do you have this item
have this but the switch itself is ruff looking....works sweet tho
colour?
black
$45 for it all??
do you have stock turbo ?
yes...unknown shaft play as the motor etc is still in the car
How much for standard cat converter? Can pickup.
condition is unknown. can take it out and check for you
is the switch 11 pin where the plug goes in, if so how much do you want for it ?
will check and confirm
boot lid?
have. has standard wing also. pm me for pics
  • 1 year later...
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
