Some of you are probably already aware that this saturday the EvolutionOz club are having their annual EvoNats at Eastern Creek. Sure the track will be limited to evos but there's a show and shine on and a few other events happening there on the day. A couple other jdm related clubs are planning on coming down and using the event as an excuse to meet up. If you want to check out some cool jap inspired rides or just have nothing much on that day you should head on down for a look.
This was a public service announcement ;)
https://www.sau.com.au/forums/topic/364793-evonats-21-5-11/
it was good. i put some pics in the monthly photo thread already. i'm about to off, i'll post up tomorrow for the lazy ones... the impatient ones can check the photo forum. who knows... u might enjoy it in there ;)
https://www.sau.com.au/forums/topic/364793-evonats-21-5-11/#findComment-5828694
    • Depends on the year/model - mine is the version of the N55 which came with an e-gate however the "PWG" (pneumatic wastegate) versions actually can also do this.  They use a vacuum setup to "pull the gate open" against the spring instead of "push it closed" like conventional wg setups.   This naturally means they can actually control boost down to a very low level/just open the gate if they want to.
    • They have e-gates. At cold start they have the gate fully open to heat the cats faster. Then during cruise as mentioned fully open wastegates reduce exhaust pumping loss.
    • Ill stick with my black Friday sale pirellis.  They were the factory option and a damn good price when on sale.
    • Hi Tao. My dump was ground out to provide clearance over the used swing arc. But when the clip fell off, the flap was free to travel too far. Got stuck. That's all. There's decent preload too. You may remember that I asked for a low pressure actuator because I wasn't able to tune the car immediately, and a proper actuator probably would have left the car undriveable. Or at least barely safely driveable. But it hasn't been an obvious problem in terms of the gate blowing open under normal use. Well, maybe it has. The turbo is quite laggy compared to stock - so an actuator upgrade will be done first after the supporting mods are done and it's dyno'd to stop it pinging. Hopefully the gate has actually been lifting early. If it has, it has been necessary for me anyway, because as I said earlier in this thread, I had to back off the ramp allowed by the boost controller, to stop it pinging. I might have been in a bit of trouble if it hadn't been as slow to build boost as I have found it. In fact - given that I will get it onto the dyno soonish - I think I'll order an actuator from you pretty soon, so we've got it there if it is clear that there's no point continuing to try tuning with the low pressure one.
    • I've always wondered why my brothers BMW is louder in Eco mode. Do they have e-gates from factory?
