A crazy new implementation from Minister for Transport, Pat Conlon, will see motorists charged a $120 fine for minor defects, and $250 fine for major defects, on top of the fees for clearing the defect notice.
all information is here
http://www.adelaidenow.com.au/motorists-slugged-for-defects/story-e6frea6u-1226058563490
https://www.sau.com.au/forums/topic/364809-new-defect-fines/
  • Replies 43
That is honest to God totally f**ked. In other words, if they don't like you... be prepared for a fine; not sure about others but if they looked hard enough they can find a defect of some sort.
If this gets out of control I can see myself not registering my car.
Yeah no joke man this is bullshit. A cop can just defect you for suspicion of being detectable even if its not. There is no point on even driving even a slightly modified car. eg having a pod filter or even just having a seat belt which doesn't retract properly.
It's pretty much giving SA pol smokers the right to f**k you over if they feel like it...
99% of defects I see are given under Suspicion...
Without actually any hard proof of damage/defect....
What happened to innocent til proven guilty ?
Makes me so glad I don't own a street rego car anymore
Not worth it in communist SA.
A firm f**k you to SA government.
More importantly where the f**k in Adelaide can I quarter mile test my car in controlled conditions?I have no way to explore my interests in my vehicles capability, and the stigma behind modified cars on the road highlights an obvious need for a full scale facility. Higher fines, double demerits and other scare tactics seem to be the only efforts the authorities are implicating, but there is still no evidence that any revenue from SAPOL has been utilized to fix our roads, provide better learner driver training, drink driving rehabilitation, fatigue management (these being things I myself would focus on) Meanwhile, even though I consider myself to be a curteous
And they keep saying they do this kind of stuff to make roads safer. Total BS if you ask me, revenue raising at its most blatant.
Makes me AAAHHHRRR!:angry:
well after completely f**king up the budget in getting Adelaide oval revamped, they need to recover the extra money spent somehow. To be totally honest this government is making things in this state worse and worse by the day, yet i don't f**king see the roads getting any better. Soon you will get fined for sneezing in the car. Arrrgh this state government is frustrating me every time they open their big flaps arrrgh
Lol, and rego fees going up as of 1st July.....
So there saving money on not sending out stickers,
But feel the need to raise renewal fees due to " 3rd party insurance going up 2.5%"
Cash grab much
On top of carbon tax that will be passed onto consumers
Water rates going up
Petrol prices
Food prices
Yet our pay stays the same....
See ya later luxury items
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
