Hi guys I have for sale twin Nismo turbos suit GTR.
One turbo needs a rebuild, so perhaps you would just get both overhauled.
After doing some research on the nismo turbos I have found out that the part number is 14411-06U00:
That corresponds with the following data I have tracked down.
32Nismo (14411-06U00) T04B T3 44.6 - 60.1 62T 0.42 T25 T25 41.7 - 53.0 CD790 .64 15° 270°~600PS
HOWEVER. The front housings are not .42A/R. The are .60A/R... which after some more tracking I believe might be off the Nismo LeMans turbos
Nismo GT/le mans (14411-RS581) T04B T3 55T 0.60 T25 T25 CD790 .64 15° 360°~640PS
So therefore it is difficult to tell exactly what the hell these are. I believe they started out as Nismo Group A's, but run the larger Nismo Le Man front housing.
Info from this site - http://homepage.ntlworld.com/tbroom/Turbos.htm
All I know if they seem to be suited for lots of boost, and are quite large.
TO4B wheel - .60A/R front - .64 A/R rear housing.
Price is $450 - open to offers.
Also have apexi (not stamped but whole exhaust was apexi branded) stainless split dumps suit above turbos (or any stock GTR turbos) for sale..
Edited by Granthem
https://www.sau.com.au/forums/topic/364812-nismo-group-ale-mans-turbos/
  • 3 weeks later...
  • 3 months later...
Its not that they arent strong stock. An oil starvation occured on the blow turbo, destroying the bearings.
Postage I assume would be around $50 as a guess, maybe slightly more.
I'm happy to chase up postage costs, but I work a busy schedule and would need to know you're dead serious before I went through all the effort. Hope you understand.
I got a pair of these bad boys on my 32 gtr came from japan with them was told i had standard turbos till i pulled off all
the pipe work to check them out and see why i wasnt hitting full boost till 5000rpm i also did a bit of research on them and
found them 2 be a group a /le mans mash up with .60 front housing apparently it was quite common back in the day in japan
to get the group a's and swap the front housing to .60 to match the size of the le mans but a lot cheaper cause the le mans were
f*king expensive and this was a cheaper alternative mine are still going strong and i make 300kw at the treads on 18psi
just thought id add some info :D
I had some lemans on my old set up, they are a bit laggy but come on like a freight train... Can get good power out of them, lag can be reduced with a good exhaust/ tune.... Was seeing 20psi at around 4500 ish
Edited by GTR_JOEY
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
