Hi there
I have just fitted a series 1 RB25 turbo to my 89 GTST/4 RB20
Every thing was ok with the RB20 turbo, but now nothing much happens until 4000rpm +
The car has a front mount, dump pipe, manual boost control (set at 14lb)
When it does come on boost it really goes hard but below 4000rpm its a pig, real laggy
The engine is healthy, good compression (about 165lb x 6 ) Also the new turbo is smooth and spins free.
I read the forums, and it would appear that lag should not be a problem doing this conversion.
Any help would be appreciated
https://www.sau.com.au/forums/topic/364814-turbo-lag/
i would point a finger at the wastegate actuator...
there is virtually no noticible difference in response between these turbos on an rb20...
make sure that the wastegate arm is as tight as possible, i remember when i changed my turbo on my r32 last time the bolts were ever so slightly loose on the actuator bracket and ti caused epic wastegate leakage
for what its worth i think that running the RB20 turbo actuator on the RB25 turbo results in more boost... i think, could be the other way around tho lol...
https://www.sau.com.au/forums/topic/364814-turbo-lag/#findComment-5820577
  • 5 years later...
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
    • Unfortunately, not only is that not the case, one of the main "Selling points" of safety over comms is they clearly state in writing that there's no need to segregate safety networks from non-safety networks. It always gets intermingled with everything else on an ICS/OT network.
    • Hello. I have an a31 cefiro but since I am in Turkey we have a CA20S engine. I did some research. Then I found that I can swap with a ca18 but when I heard that it has the similar substructure as the s13. I thought I can swap with an sr20 because the sr20 was used with the s13. So can I easily swap the sr20 on my cefiro or is it difficult?
    • I used to love stock take. I used to take f**k of a lot of stock. /Rodney Rude.
