Hi there
I have just fitted a series 1 RB25 turbo to my 89 GTST/4 RB20
Every thing was ok with the RB20 turbo, but now nothing much happens until 4000rpm +
The car has a front mount, dump pipe, manual boost control (set at 14lb)
When it does come on boost it really goes hard but below 4000rpm its a pig, real laggy
The engine is healthy, good compression (about 165lb x 6 ) Also the new turbo is smooth and spins free.
I read the forums, and it would appear that lag should not be a problem doing this conversion.
Any help would be appreciated
https://www.sau.com.au/forums/topic/364814-turbo-lag/
i would point a finger at the wastegate actuator...
there is virtually no noticible difference in response between these turbos on an rb20...
make sure that the wastegate arm is as tight as possible, i remember when i changed my turbo on my r32 last time the bolts were ever so slightly loose on the actuator bracket and ti caused epic wastegate leakage
for what its worth i think that running the RB20 turbo actuator on the RB25 turbo results in more boost... i think, could be the other way around tho lol...
https://www.sau.com.au/forums/topic/364814-turbo-lag/#findComment-5820577
  • 5 years later...
