Hi guys,
Set of Enkei RPF1 rims for sale. F1 Silver - super lightweight.
Specs are:
5 * 114.3
18 * 9 +35 rear - 245/45/18 Tires - camber worn on edges (but still legal), bulk meat in the middle
18 * 8.5 + 35 front - 265/35/18 Federal SS tires - probably a few thousand K old. Heaps of tread.
Good condition. Stickers in perfect nick. One rear rim has a slight graze. There are some slight marks that come with used rims.
This is how they sit on my GTS-t rear - sits pretty good at the rear, front tuck in abit with camber if slammed.
Price: $1800ono
Pics:
https://www.sau.com.au/forums/topic/364815-enkei-rpf1-18s/
  • 3 months later...
Haha cheers guys.
Tell me about it - I would love them with some more offset. The rear sits pretty good, fronts could use a spacer ideally.
I purchased 20 inch Meisters though and always planned to keep these rims. I do love them, but seeing them sit in my living room seems like a waste. I'd rather them be sitting on someones skyline and doing what they are meant to.
I think the price is quite reasonable aswell.
https://www.sau.com.au/forums/topic/364815-enkei-rpf1-18s/#findComment-6025395
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
