  On 20/05/2011 at 2:22 AM, simpletool said:
If you want a good looking drag car it's not a bad idea, but might as well use an alloy V8 and twin turbo. :/
The entire point of an RX7 is the handling and packaging possible from the low weight and small size of the engine. :yes:
This!
Not to mention the 13B is a f**king potent motor anyhow
  On 20/05/2011 at 1:30 AM, NickR33 said:
I think there's a few LS into RX7 conversions in the states... that makes more sense as at least your replacing the rotor with a more reliable engine... rather than replacing a motor that's prone to overheating and eating apex seals with motor that's prone to eating bearings
There's a red one in NSW that has the conversion done and races. I believe there is a kit you can buy to do the conversion
edit: Bit slow with my post on the kits
there was a great motor swap i heard about: a landcruiser straight 6 in a supra; 4500cc i think.
amazing!!! didnt get to see the final results but the torque must be able to spin the earth backwards.
An idea i had was a ford xr6 turbo motor in a gtr. wonder if anyone has tried?
The LS into RX7 conversion has a couple of drawbacks. Either the engine sits too high (raising COG and needing a bonnet bulge), or you have to mod the Xmember to lower the engine. This required modded "dropped" tie rod ends which apparently bugger up steering geometry and induce bump steer. Might be able to dry sump the engine to lower its height and alleviate these problems.
But yes, LS into anything would be a good conversion (personally I'd like an old Beemer 540i, with 520 badges and a tricked up LS6 under the bonnet.) Could have picked up a 540i for a few grand a year ago, but don't have time for such silly conversions.
To much weight me thinks... unless they are alloy
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
