Cruising down the highway I dropped to 3rd to overtake and something went bang, complete loss of power and black smoke pouring out the exhaust. I had to drive another 5 mins to get home and i had to quickly swap cars to go to the dr so I haven't looked yet, my main question is do you normally hear your turbo explode?
https://www.sau.com.au/forums/topic/364836-my-car-just-went-bang/
  • Replies 205
It is still running ok. Feels like when I blew an Intercooler pipe in my celica, that's what makes me think turbo. I don't think there was any other noises but my car has lots of random noises so I just might not have noticed. Smoke when boost should be. My wife said it looks like fuel smoke.
If you've got no boost (power) and all it does is smoke, then I truly believe you've blown the turbo.
If it was a blown cooler pipe, your car wouldn't run ... barely idle.
I say pull the dump pipe off and look for a missing turbine wheel.
:thumbsup:
Anyone got any ideas for removing the bolts in the dump pipe. I snapped one when I put the jjr dump on and now I've got one stuck again :/
If it's stuck, drown it in WD40 or similar, leave it to soak; then loosen a little until it binds. Drown again, wind the bolt back in until it binds; this will work the WD down the thread. Just work the bolt back and forth; you may get it out.
If you find it seizes solid; it may be better to just break the bolt off, (ie turn it until the head breaks off) remove turbo and drill out, re-tap and re- stud.
It's a pain in the arse I know, but then you know it's right.:thumbsup:
Edited by Daleo
Try removing the turbo with dump pipe attached, by undoing the 4 nuts holding it to the exhaust manifold. Undo all your lines etc. Its a pita but you'll have it off quicker than f**king about with tight bolts on the dump. Once off you can then separate the dump and replace the seized bolts. Chances are, you'll need the turbo off anyway to rebuild.
I do this to my turbo when I want the dump off, because its a bellmouth pipe with bugger all room to remove whilst the turbo is on the car :laugh:
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
