Try www.Injectorsonline.com they are in Melbourne and can do their modified and flowmatched 1000cc 3/4 length 14mm Bosch/ID's for around $700. They idle perfectly in my car. Otherwise they do the usual Deka 610's pretty cheap too. Ask them if they will price match, you may be surprised.
  • Replies 205
Pipster. There is some ls injectors on eBay and it says falcon needs different plugs. Why can't all companies just use the same plugs :/
yeah i think they use their own plugs, bit annoying
just buy chef_stagea's injectors, they come with a loom to suit them and all the spacers needed etc.
check the stagea classifieds
What's wrong with the HKS ones? Direct fit for your motor at about $450 + postage.
wow that cheap, probably the best way to go
try and get something with 4 holes too, better spray pattern for better fuel consumption and i think you get a bit more power
Damn that's cheap. Not sure how big there are but if you need something bigger, 600 cc from Deatschwerks are only 550 US atm, and the exchange rate is pretty good... I am using these:
www.deatschwerks.com/skyline/skyline-1998-2002
PS they are a direct fit, and include postage IIRC
Edited by DaveB
ok kewl, im getting an atr43ss-1 $1480 delived with oil line :D just hopeing the wastegate actuator isnt too high of a pressure.
let us know how it goes, thats what i was thinking of replacing mine with
or a g3
Hi
I have 6 850cc power enterprise injectors here if your game they were to big for what i wanted i used 550cc instead. I also have a Z32 afm if you are interested.
If you want the full story on these parts just PM me.
Lmao. How was traction at 250kw??
fine, it never broke traction. i do have 245's on it, and i think having an auto helps with traction. i cant just drop the clutch and get instant power. even now in the wet it's hard to get it to break traction, got to be turning and get weight off the driven wheel to get it into a slide, but the 4WD straightens it out almost straight away anyway.
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
