Firstly, YES I'VE SEARCHED!!!!!!! - results arent really helping me!
I've got a S2 RB25DET with approx 40k on the clock. Running stock boost, 3" exhaust, near new Yellow Jacket coil packs, BCPR6ES plugs gapped to 0.8
Was running fine until yesterday around 4500~5000 rpm its hesitant with a noticeable misfire almost all the way up to redline. Sometimes it does it, sometimes not.
I put in new spark plugs, checked/changed AFM, checked all vac lines for leaks etc etc and couldnt find anything. All wiring looks ok too.
Any suggestions???
https://www.sau.com.au/forums/topic/364847-another-miss-fire-thread/
misfire is dead obvious
it will loudly pop fart and sound like a shotgon or machine gun
describe the misfire
have you checked the basics such as plugs, loom inspection and visual sight of the coils etc
Similar thing with mine mate, could be the ecu. Mine got noticeably worse with the more mods i did. Was very slight with stock boost and cat back zorst, then will full zorst and 10 psi it was made much worse. Having said that, most people on standard boost dont have a problem. (i did)
Same cause as always, running extra boost puts ecu into R&R, running richer makes weak spark more obvious.
Two problems, ultimately fix both, you have weak spark due to old stuffed coils, wrong plugs, wrong gap (I think it is coils here). The other problem is running massively rich due to stock tune and extra boost, get a nistune or PFC and fix the tune up.
You will get better fuel economy, more power and no misfire if you do the above. Usually fixing just one of the above will fix the misfire, but you should fix both.
Boost leak will also cause the similar symptoms due to running massively rich (below 10:1), check all silicon joiners etc for boost leak, though majority of the time it is coils as it is happening at peak torque, if it was happening across the board it would be more likely boost leak.
Edited by Rolls
Any suggestions???
Sounds a lot like what mine was doing, different setups, boost, etc.... for the $30 or whatever they cost try BCPR7ES (0.8).
Can't really explain it myself, but it was running fine then started to miss... miss got worse and worse. Tried new BCPR6ES plugs... no help.
The 7s sorted it.
I had brand new yellow jackets fail in a matter of weeks. One died gave me five running cylinders. Then the misfires started. Try the cheapest, easiest option. Spark plugs. BCP7RES. Cost me $20 for all 6. Then try get some stock coils and fit them of IF the plugs didn't help.
It sounds like a machine gun as others have said. A very fast sequence of fart attacks.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
