-7 Turbos, hot side ceramic coated, reco'ed by GCG 5k km ago, with adjustable wastegate actuators, always run with pre-filter to avoid contamination. Max 18 psi and have made 305 rwkw on a 26/30. No damage to wheels, just no pics as the photos were taken for me. Selling because I need larger units. Note the dumps in the pics are not included. HPC coating and r&r of the housings was $600 alone, plus adjustable actuators. Can be inspected in Western Sydney. $1900 ono plus postage. Happy to negotiate but no lowballs please folks I don't have to sell them.
N1 Oil pump 5k km old, run with a crank collar and ATI balancer, never been on the limiter and never been over 7250 rpm. $180 firm plus postage. Can also be inspected in Western Sydney.
Consider swapping for R34 GTR 3.5 ratio front and rear diffs in excellent condition plus cash my way.
Any questions please PM.
Thanks.
Edited by Scooby
https://www.sau.com.au/forums/topic/364874-gtr-r34-n1-7-turbos-and-n1-oil-pump/
Hi there, I take it that the N1's are still up for grabs? Just wondering if they fit on R33 GTR stock manifolds (I know that R32 and 33 are interchangeable but not so sure about R34's)
Thanks,
Tom
  • 3 weeks later...
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
