Hey everyone, i'll try and keep this short so its easy to read.
I'm building an RB26 for race use. Now i dont have unlimited cash for it, but i havn't really set out a budget yet either. But i'm looking to buy the best quality parts i can get without being rediculous...
What i want the engine to be able to do;
Power: 300 - 350kW
Power range: 3,000 - 8,500/9,000RPM, yes i want it to rev high!
Reliability and longevity
Response within that rev range.
Now i'm not interested in talking about turbos, manifolds or fuel systems at this point, just engine internal parts, block and head..
Basically what i'm asking for is your advice on what parts i should be getting, your personal opinion, value for money, have you heard of XX part failing and what happened etc etc. Just wanting some input so i can make up my mind and start purchasing.
I'll be after advice on;
Rods
Pistons
Rings
Bearings
ARP Studs will be used throughout...
Gaskets (mainly head gasket)
Oil pumps - I'm thinking Tomei
Harmonic balancer
Clutch - I'll need this for when the engine is being assembled...
Head components;
Cams
Valve springs
Valves
Valve guides/seats
Just throw us some feedback on what you thinks good guys.
I'm hoping to have ALL the long motor parts for $8k - $10k. Then there will be engine assembly, manifolds, turbo, fuel system, management, pipework etc costs on top of that.
My main goal is to make this engine last for a long time!
Lets see,
In a nutshell that power is attainable without forging... but if u wana boooosttttt ull need to start changing bits in order to get that power and still be safe
There is a kit on HighOctane that has everything you need for a forged build for 4600 i think its perfect for what you want as im geting the same one! :)
One of the main ones is the oil pump .. in a nutshell GO TOMEI lol ull thank god so much in the long run that u spent the extra moneys on that as oil issues is huge on the 26 also make sure u get that oil restrictor
Headgasket and all other gaskets in this kit are tomei so u have no dramas with quality ur option on what size u want
Now with that 8500 to 9000 rpm u want ur going to have to go sexy cams with double valvesprings i highly recommend you have a look at CAMTECH cams they have kits to suit the 26 and are far more advanced than ur off the shelf crap from hks and tomei as advertised durations are not correctly displayed these guys are the shit :)
let me know how it goes choosing !
10k is pretty restrictive for that RPM range.
I know you don't want to talk turbos etc, but that choice is quite critical in you decision.
The reason i say this is because for 300-350rwkw, all turbos that fit that power range do not need more than 7500rpm or there abouts. Hence aiming for 8500+ is kinda pointless and will add excessive cost when you simply don't need it :)
Also with regards to parts, any can be killed and there are is always a horror story. So that request in itself is hard to answer and it will more so come down to how well the motor is assembled and tuned over and above the specific brand.
Bang on there!
Generally the lower you can keep your revs the longer everything will last.
I know, i have thought of this. Small power output, needs a smaller turbo. Higher revs needs a larger turbo = more power. To get a 26 to rev to that, you'd a fairly large turbo so that it operates in its efficiency range.
I just love a high revving engine, its just bliss!
Tomei pump is pretty much a goer, yes i have looked at camtech cams before.
I will be running forged internals, even though stock Nissan items would cope, i want that piece of mind.
It might be bliss to the ears but it's excruciating pain to the wallet and IMO 10k isn't going to be enough anyway.
I mean just between the clutch, oil pump, new crank & pistons you are already @ around 5.5k-6k - Shit gets expensive if you want more RPM, very expensive.
I get the feeling you are going towards:
330-340rwkw
As much response as possible
And we can forget 8500+ :teehee:
For 10k, with the bits you want... 8000rpm limit, 2.6l bottom end done, head rebuild - i reckon you won't have a cent left outta 10k
Plus its a race motor, going to have its balls rung each time it goes out. Makes sense to keep RPM lower if you don't really need it.
I can see your point, and i agree with it. Probably wanting something that just isn't realistic. Yes i'm chasing around 350kW, as anything more just isn't going to be any use in an R31.
I did know it was going to be an impossible task to get an engine to rev high on a budget but ah well.
The more important factors are;
Reliability and longevity and response.
Maybe look at getting a mild port done, remove the bumps in the exhaust port and polish, 80 grit the inlets and knife edge the splitter, polish combustion chambers and leave quench area (maybe just chamfer the edge on it). I ended up doing this to my head myself, just purchased a head porting kit of ebay, came up really good. As for the turbos -7s, -5s, even -9s? all depends on what you want out of your engine. Cams you dont really need to change, maybe just get adjustable cam gears and have them dialed in when tunning it? Could even use direct drop 260 degree 9.15mm in/ex but again all depends what you want out of your engine. Im actually going through a rebuild with mine atm and am way over the 10 grand mark!
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
