1997 Nissan Skyline GT-R V-Spec
Series 3
10 months rego
104000kms
$32,500obo
I am the first owner here in Oz, had it for the last 3 or so yrs. It has had NSW rego for the last 2yrs.
500awhp
Power FC Pro
New Turbosmart EB2
New 2 x Turbosmart dual port BOV's
New Turbosmart FPR800
HKS intercooler
HKS 25/30 BB turbos
HKS 1 bar actuators
HKS dump pipes
HKS super hipower exhaust
New Platinum Motorsport 272 deg cams and cam gears.
(Lumpy cams, still very drivable - See the video in the link below.)
New Splitfire coils
Apexi pod filters
Z32 AFM's
800cc inj's
Deutchwerx 300lph fuel pump
HKS Hardpipe kit
New Nismo Coppermix twin plate C-Spec clutch ($4k!) Drives like a dream compared to the previous triple plate.
Cusco adjustable castor rods
Enkei RPF1 18x10.5 wheels
New Nitto 555ZR 275x35x18 all round
Slotted rear discs
Endless front discs
Apexi El-glow guages inset into dash (Exh temp, Oil pressure and temp)
Pioneer MP3 cd player with USB, and SD card reader.
N1 bonnet lip
side mounted oil cooler with indicator vent
clear side and front indicators
The body has a few minor blemishes. One of the xenon headlight globes has busted and the plug needs replacing too. There is some rash on the rims. Consider it evidence that it is driven and not hidden, and built to be reliable, not show pony.
This is a very reluctant sale.
No test pilots. Bring a bank statement before even asking me about the car.
Price is neg. but let the money do the talking.
Lumpy Cam Video
GTR Photo Album
Edited by -troy-
Thx fellas.
As you can see from the pics, its all there. I know it has its blemishes too. $31k for it all fixed but I'd be willing to take a couple of $k off as is. Anyone keen to negotiate?
EOFYS bro!! spend up!
    • I have a VALCON if anyone wants it, I have no idea why you'd want to have VVT specifically broken out of the ECU as opposed to running it off the FCON/whatever standalone you have.
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
    • Transplanting the vvt from a 25neo into an rb26?
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
