GTRAAH Posted May 19, 2011 Share Posted May 19, 2011 Lets say your car makes 330kw at all wheels whats that in BHP & HP. And whats the difference from BHP to just normal HP. When a car is advertised brand new do they ever tell you the AWKW or is it engine KW? Link to comment https://www.sau.com.au/forums/topic/364910-bhp-tp-hp-kw-awkw/ Share on other sites More sharing options...
KiwiRS4T Posted May 19, 2011 Share Posted May 19, 2011 Try googling those terms. Link to comment https://www.sau.com.au/forums/topic/364910-bhp-tp-hp-kw-awkw/#findComment-5822101 Share on other sites More sharing options...
tridentt150v Posted May 19, 2011 Share Posted May 19, 2011 Are you from Punxsutawney? Link to comment https://www.sau.com.au/forums/topic/364910-bhp-tp-hp-kw-awkw/#findComment-5822147 Share on other sites More sharing options...
PM-R33 Posted May 20, 2011 Share Posted May 20, 2011 And whats the difference from BHP to just normal HP. BHP refers to an engines power with nothing else dragging it down (no mufflers/gearbox/diff/aux components etc). So in reality it is the power the engine makes before it is put into the car hooked up onto an engine dyno in a workshop. HP is just the overall unit of measurement and can refer to anything eg. HP @ the wheels. Lets say your car makes 330kw at all wheels whats that in BHP & HP. 330kw@wheels is around 442hp@wheels. To convert that to BHP is more of a guessing game and gets brought up on the forums quite a lot. Most methods people say are completely wrong (percentage, fixed amount etc). The only way to truely convert it is to know the BHP of the engine, then to know the HP@wheels of that exact same engine. Work out the loss of power and use that as your "x". Then when you have more power, so in your case 442hp@wheels, add the "x" and this will be your rough lowest amount of BHP. It will naturally be a bit more than this as there will be more loss, but this can't be worked out accurately enough for the sake of these discussions. There are a lot of factors that come into play and it gets quite technical. So just quickly as an example (I have done this one a few times in the past). Car makes 400BHP when new. Same car put onto a dyno makes 350HP@wheels. Loss of 50HP. Three years later the car has been modified with an exhaust, tune and more boost and now makes 500HP@wheels. Add back original loss of 50HP. The rough lowest amount of BHP is 550BHP. However in reality it will obviously be slightly more than this as more loss has occured. When a car is advertised brand new do they ever tell you the AWKW or is it engine KW? Only ever BHP. Hope that clears all that up for you. Link to comment https://www.sau.com.au/forums/topic/364910-bhp-tp-hp-kw-awkw/#findComment-5822294 Share on other sites More sharing options...
zebra Posted May 20, 2011 Share Posted May 20, 2011 Only ever BHP. Hope that clears all that up for you. Execpt sometimes those figures a kinda fudged lol. eg the new supercharged V8 falcons, are rated at 335kws at the flywheel, but they reel off 340rwkws dead standard lol so it would make 335kws somewhere in the rev range. Link to comment https://www.sau.com.au/forums/topic/364910-bhp-tp-hp-kw-awkw/#findComment-5822440 Share on other sites More sharing options...
PM-R33 Posted May 20, 2011 Share Posted May 20, 2011 Yeah they bullshit the figures sometimes. But they are ment to be rated as BHP. Really? They make that much at the wheels standard? Wow. Link to comment https://www.sau.com.au/forums/topic/364910-bhp-tp-hp-kw-awkw/#findComment-5822506 Share on other sites More sharing options...
zebra Posted May 20, 2011 Share Posted May 20, 2011 Yeah they bullshit the figures sometimes. But they are ment to be rated as BHP. Really? They make that much at the wheels standard? Wow. Yeah...it does make sense though, I mean the standard NA 5L makes 307kw, then they strap an Harrop HTV1900 blower on it an only make a few killerwasps more...yeah right lol Link to comment https://www.sau.com.au/forums/topic/364910-bhp-tp-hp-kw-awkw/#findComment-5822512 Share on other sites More sharing options...
simpletool Posted May 20, 2011 Share Posted May 20, 2011 (edited) They are bloody pathetic at getting that power to the ground then !!! Obviously need some 19 x 10 on the back and 275/35/19s. Btw each car is different. I use [(Engine Kw)-15]x 0.85 = rwkw.................. ...............but then again...I'm a d!ckhead. Edited May 20, 2011 by simpletool Link to comment https://www.sau.com.au/forums/topic/364910-bhp-tp-hp-kw-awkw/#findComment-5822563 Share on other sites More sharing options...
TiTAN Posted May 20, 2011 Share Posted May 20, 2011 They are bloody pathetic at getting that power to the ground then !!! Obviously need some 19 x 10 on the back and 275/35/19s. Btw each car is different. I use [(Engine Kw)-15]x 0.85 = rwkw.................. ...............but then again...I'm a d!ckhead. its easier to just do HP x 0.746 (or 0.75) = KW or the other way KW x 1.36 = HP Link to comment https://www.sau.com.au/forums/topic/364910-bhp-tp-hp-kw-awkw/#findComment-5822883 Share on other sites More sharing options...
Harey Posted May 20, 2011 Share Posted May 20, 2011 Execpt sometimes those figures a kinda fudged lol. eg the new supercharged V8 falcons, are rated at 335kws at the flywheel, but they reel off 340rwkws dead standard lol so it would make 335kws somewhere in the rev range. Are you sure 340rwkw dead standard?? I read about one that had the boost turned up and tuned making that power. I know they are bloody impressive but I dont think 340rwkw dead standard. Link to comment https://www.sau.com.au/forums/topic/364910-bhp-tp-hp-kw-awkw/#findComment-5822884 Share on other sites More sharing options...
zebra Posted May 20, 2011 Share Posted May 20, 2011 Are you sure 340rwkw dead standard?? I read about one that had the boost turned up and tuned making that power. I know they are bloody impressive but I dont think 340rwkw dead standard. seen a few dyno runs now...one even ran 353rwkws but is a rather happy dyno with a tune, good exhasut and WMI they will do 400rwkws. Cant wait for the intercooled ones, so they can throw some real boost into them so even if we say they are all happy dynos, how many are happy by even 40kws? edit - they run 114mph through the traps on street tyres, they weigh 1820kgs + driver Link to comment https://www.sau.com.au/forums/topic/364910-bhp-tp-hp-kw-awkw/#findComment-5822895 Share on other sites More sharing options...
simpletool Posted May 20, 2011 Share Posted May 20, 2011 its easier to just do HP x 0.746 (or 0.75) = KWor the other way KW x 1.36 = HP except I was converting flywheel to rear wheel. Not horsepower to kw. Link to comment https://www.sau.com.au/forums/topic/364910-bhp-tp-hp-kw-awkw/#findComment-5822900 Share on other sites More sharing options...
simpletool Posted May 20, 2011 Share Posted May 20, 2011 seen a few dyno runs now...one even ran 353rwkws but is a rather happy dynowith a tune, good exhasut and WMI they will do 400rwkws.Cant wait for the intercooled ones, so they can throw some real boost into them Gearbox says no. 353rwkw so around 430kw at the engine. That's 240kw/tonne or 116 mph trap speed (minimum). Link to comment https://www.sau.com.au/forums/topic/364910-bhp-tp-hp-kw-awkw/#findComment-5822944 Share on other sites More sharing options...
zebra Posted May 20, 2011 Share Posted May 20, 2011 yeah hence me saying the 350rwkw run was happy at that weight 114mph is ~ 485hp / 360kw at the fly, but thats not allowing for the epic skids they lay down the strip, I have no doubts they make 500hp at the flywheel. Link to comment https://www.sau.com.au/forums/topic/364910-bhp-tp-hp-kw-awkw/#findComment-5822953 Share on other sites More sharing options...
jangles Posted May 20, 2011 Share Posted May 20, 2011 standard wheel combos are pathetic! they rotate a lot also! 340kw stock is about what all of them are getting Link to comment https://www.sau.com.au/forums/topic/364910-bhp-tp-hp-kw-awkw/#findComment-5823692 Share on other sites More sharing options...
Rolls Posted May 20, 2011 Share Posted May 20, 2011 what is a standard wheel combo? Link to comment https://www.sau.com.au/forums/topic/364910-bhp-tp-hp-kw-awkw/#findComment-5823938 Share on other sites More sharing options...
linkems Posted May 20, 2011 Share Posted May 20, 2011 I don't think they make that power stock the gs rated 315 from factory pulls about 260rwkw then after tune without any other modifications 380rwkw. I'd say gt would be about 280rwkw at most. Take note that once tuned the gs/gt are identical power. exhaust, pulley, water injection Link to comment https://www.sau.com.au/forums/topic/364910-bhp-tp-hp-kw-awkw/#findComment-5824057 Share on other sites More sharing options...
iplen Posted May 20, 2011 Share Posted May 20, 2011 These new motors are crazy, wish I could pick up 120kw from a tune... Who wants to put one in a GTR??? Link to comment https://www.sau.com.au/forums/topic/364910-bhp-tp-hp-kw-awkw/#findComment-5824091 Share on other sites More sharing options...
TurboMick Posted May 21, 2011 Share Posted May 21, 2011 (edited) Has anyone seen what the dyno readout looks like after 2-3 runs though?<br>Massive heatsoak in the 'heat diffuser', then the PCM shuts down the maximum<div>throttle position to around 30%.....<br>One good run down the track, then an hour and a half waiting for the <br>temps to drop to normal hahaha. </div> Edited May 21, 2011 by TurboMick Link to comment https://www.sau.com.au/forums/topic/364910-bhp-tp-hp-kw-awkw/#findComment-5824505 Share on other sites More sharing options...
Pal Posted May 21, 2011 Share Posted May 21, 2011 i use thins converter http://www.mr2ownersclub.com/converter.htm Link to comment https://www.sau.com.au/forums/topic/364910-bhp-tp-hp-kw-awkw/#findComment-5824813 Share on other sites More sharing options...
