Hey guys, would anyone if the low max seats sit lower than factory gtt seats? as I have clearance issues with a helmet on.
Darren, I have bride rails that are a direct fit for my car and I would like to know if the low max seats or any other Bride seats fit these rails. Or do you need to get different rails for different seats? Also are the carbon kevlar lighter than the standard priced seats? Or is just for show?
  • Replies 67
The seats do sit lower, a fair bit actually. And also maybe I got lower rails too.
I know for a fact that genuine Recaro SR3 rails will fit the Gias, as I have one in my car with the Recaro rails.
Yeah I've got a Recaro reclinable at the moment and my head rubs in my S14a without a helmet, I'm 6'1". The LF rails are $300 but I guess it's worth it for around $550 total if I can fit properly.
Im about the same height, though I think there is more room in my skyline.
So final decision is the Vios fixed back then?
Hi Charles, its Dimi here. I bough the car mats of you action-smiley-069.gif
I remember sitting in your seat and thats what I want. Nice and low!
Oh hey bro :)
Haha yeah, I wanna upgrade to Gias 2 (only for quick release), maybe share a pair with me? :P
I have started a new thread wiyh more information, better pricing and revised start and end dates
Please refer to new thread for all details, discussion and ordering
This one will be be closed in 1 week
Please do not respond here
Link to new thread
http://www.skylinesaustralia.com/forums/topic/367704-bride-style-seats-thread-no-2/
Edited by darrinspencer
Guest
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
