  • Replies 436
Posted Images
So is that gospel then? have run a 11.92 previously, hoping to run quicker this time.
Do i need to hook up something or will it get through scrutineering ok?
I wouldnt be to worried about it. Normally at these events you self scrutineer your car anyway. I would just throw a blue triangle on the car just so they know where the islation switch is. I have run an 11.0 and i am meant to have a lot more safety gear in the car than i do have and they have never said anything to me about it. I would be more concerned about an ANDRA licence than the isolation switch. You do have an ANDRA licence dont you? They can probably be purchased on the day but its quite a bit more expensive doing it that way. If you plan on continuing to race the car it would be much cheaper to buy a yearly licence
Bank transfer done.
Emailed entry form.
We may finally have that race Brad (ido09s) :thumbsup:
Oh sweet. Will be good to catch up mate and have that long awaited race :nyaanyaa: How did your car go on E85? Did you make much more power? Ours went backwards according to the rollers hehe
Given the event is only a week away and there is only around 30 competitors.... is it going to go ahead or not? Unless the club makes up for the shortfall in costs i thought that WSID had a minimum of 40 cars, max of 50, for these private hires.
It's all in the first post;
4. Club Execs will be at the entry gate from 830am until 10am to hand out tickets. Get there before 10am to get a ticket, we wont stand there all day as we're there to enjoy the day aswel :)
IDO09S, Aaron (1320ft) has made himself available to be there on the day and can issue the ANDRA licences. I am sure he will post in here to answer any questions.
As usual, I wouldn't be surprised if there were a number of last-minute entries and SAU reached the minimum 40 entries. The track day is booked and it's going ahead...unless the track isn't ready :unsure:
Awesome about Aaron being there :rolleyes: Aaron is pretty fair with running the joint from an ANDRA perspective
I am with you on the track conditions..... have they had a street meet yet to get some rubber down? We might be the first to christen the new surface, which i wont be happy about to be honest :( The new management is doing an awesome job with the place though. Its come ahead in leaps and bounds since the departure of Jim Read
Getting tuned, will find out next week mate :whistling:
Edited by petern
Hey fellas, I don't know if WSID will let us run our GoPro's but I have the three for the club up for rent. Is $35 paid on the day. That includes me making DVD copy of the video files and mailing them to you about a week after the event.
PM me for reserving one. First in, best dressed.
I ran mine inside the car and have had no problems.. I Dont think outside the car is allowed..
Entries will be updated shortly, we are closing in on the 40 entrants :)
I always have my gopro hanging from the sunroof inside the car and they havent pulled me up on it so far.
I would like to try it outside the car this time so lets see what they say.
Cars use them on the outside all the time so i doubt they will have any problems with it.
The new management seems to be a bit more laid back than the old management which is good to see as they were pretty hard assed on trivial things previously
If you like Jarrod just send me a PM with all of your details that should be on the form and ill do it for you.. (im thinking you are just using microsoft word viewer not the actual program so you cant edit documents)
This event is absolutely going forward, and it's going to be great :D
There are about 15 spots remaining until we are full, but WSID require us to cut off entries after this weekend.
So get in quickly!
Thats fine, Matt is being paid to cover the event and the agreement I made with him is that he's the only one who will get a Media pass on the day but around the pits or from the stands is no drama.
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
