  • Replies 436
Posted Images
There are ways around this... you could break the beam (and start the timers) then take off and see what MPH you can get. This can indicate your potential ET on a perfect run. Or you could take off easy and then plant it - again, to see what MPH is acheived on the run, and hence what potential ET the car is capable of.
Alternatively, you could take off hard and then either back off or brake before the finish line. Couple the first half track passes with the MPH acheived on the other runs and you can work out the opotimal run ET and TS. Then, go hard at the end of the day and get your 10second timeslip and get booted :D
/waves@Aaron :D:action-smiley-069::whistling:
That must have been quite a while ago and WSID's private days were much different back then. Now they have two types, ones like this SAU:NSW one (ie 11.00+ cars), and the private track hire days for ANDRA-teched cars (a handful of cars only).
Is there truth to the rumor that if it's blatantly obvious by your 60" foot that you're holding off that you can get booted by that time even if you don't run a 10?
The rule book does allow it, but it only gets used if you are being an idiot or a c*nt towards the officials etc.
just looked through the ANDRA rule book and can't see anything about 60" but there is a time limit of 7secs for the 1/8th mile
I was just reading in the previous event (2007) where several cars ran within 5 or 7 hundreths of breaking into 10's and was fine. So sounds like it isn't a "fuzzy" rule, but I guess one of the guys that is closer to the rules could answer definitively.
List is all updated to date.. Come on everyone, you wanted it and said u would come and now you have all dropped off..
Tell your friends and get entered because if you dont do it now it may never come back!
There is nothing about a short time to get you booted, just ET or trap speed.
You can also be booted if you are running quicker than 12.50 and have slicks without front runners. I did this in testing and sandbagged at half track .. and got booted.
Guest
