So here I am daydreaming again, this time about the upcoming (?) new rotary engine from Mazda, the 16X.
Summary:
2 x 800cc rotors
Direct injection
Increased compression
More fuel efficient
(probably less revs)
Here's my dreams/guestimations/predictions....
MX5 with 16X (NA), Torque 270Nm. Power 187kw @7300rpm
RX8 with same engine and hybrid drive. (http://www.roadandtrack.com/future-cars/2014-mazda-rx-8)
RX7 with 16X single turbo (mild boost 8psi). Torque 370Nm. Power 235kw @6800rpm. Weight 1260kg (2 seater only with rear luggage bench).
Here's hoping they build something like these.
With light weight and direct injection the rotary could be quite decent on fuel.
https://www.sau.com.au/forums/topic/364936-mazda-16x-rotary/
I just hope they keep the rotary engine available. Its always nice know that some manufacturers are still making sports cars.
Take note toyota, honda & mitsubishi (if you sre still going to kill off the evo).
Edited by gtr fan
Mazda has doubled the number of engineers on the rotary in the last 12 months. So it appears to be something that IS happening. The completely fresh design, direct injection and longer stroke should make it use a LOT less fuel....as long as they only go into light cars.
Although the RX8 was comparatively light it was still too heavy for the 13B. The 16X should have about 30% more torque.
Please please put it in an MX5, then turbo and put into a 2-seater RX7.
Why bother putting it into a mx5? They already have nice little engines that turbo/supercharge up plenty as it is. Easier to do that than to do an engine conversion.
No I'm saying Mazda should do it. Would be very easy for them. Apparently Mazda UK has put in an expression of interest to Mazda HQ for said car.
And a turbo/supercharged 4-cyl isn't really that comparable to a NA rotary.
    • Middle seat good for a slab of beer or Esky for a road trip. 2x kids, means 1x free seat lol.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
