Wrecking everything from an R33, some of the stuff is already gone, but post up in here what you're after and i'll PM you if i have it.
few key bits:
Engine (minus injectors, turbo and ecu) - $1500
Turbo - HKS 25/30 - $900
Gearbox - SOLD
Suspension is complete, so pretty much everything from there is available at this point.
Also looking for someone who wants to take the shell, it has sustained damage at the front corner, the radiator support has been moved at the top (ok at the bottom, but needs to be replaced), all the suspension and arms looks ok, the strut tower hasnt been moved, the chassis rails are fine. Is a economic write off, so no rego til it goes through inspection
Rolling w/interior - $1300
Rolling no interior - $1000
Not rolling, no interior - $500
prices aren't with brakes, that will be extra.
Located near Mitcham in SA, but can post most parts anywhere.
https://www.sau.com.au/forums/topic/364944-s-a-w-r-e-c-k-i-n-g-r-3-3/
  • 4 weeks later...
hey guys, suspension has been taken out, turbo sold.
also engine has a separate thread now:
http://www.skylinesaustralia.com/forums/topic/367649-s-a-r-b-2-5-engine/page__p__5864338__fromsearch__1#entry5864338
  • 3 weeks later...
    • Hey VQ Member,   The FB Infiniti group wants to arrange a meet Sydney meet up, are there any members in the Sydney area who like to meet up. Let me know what you think ppl.
    • The small boxes will wear out the input shaft bearings.....if and only if you seriously exceed the torque input that they were designed to handle. It is very common for them to give up after a few years behind bosted RB20s and if you put a 25 turbo in front of them they can't last forever. Behind an NA RB20? Should last forever and ever and ever and ever. If it has died, it is from some sort of mistreatment, or perhaps extremely bad luck.
    • I’m going Barra fishing with my mate this weekend coming so I could probably stop in at yours on the way back home maybe Sunday arvo or Monday morning.
    • EDIT: Just a little info what my tranny is "doing" :   For the long time the trans do this "bad" sound:https://www.youtube.com/watch?v=qs_iTXgDt40 It is literally the same sound and same symptoms(when i push the clutch it quites down) So is it really the shaft bearing?   Also:  i found this on forums: The RB20 and SR20 boxes are nearly indentical inside (rb20 has longer mainshaft)and suffer badly from bearing and selector failures when driven hard   The bearing is true and selector failure kinda too...it is "harder" to get into gears specialy when i drive a little bit hard...
