I have a set of four (4) Starcorp Agle wheels for sale.
They are painted in shadow chrome with a polished lip and sit good on a R33 Skyline GTS-25T.
post-24210-0-25300600-1305868727_thumb.jpg post-24210-0-64035700-1305870212_thumb.jpg
To clear Skyline brakes, the rims come with 12 mm hubcentric spacers and special wheel nuts that fit through the wheel and spacers and do up perfectly on standard studs.
The Fronts are 18x8.5's with a +38 offset plus the spacers comes down to +26 offset. The tyres are Pirelli P Zero Rosso's in 235/40 R18's with 3mm of tread.
post-24210-0-62213900-1305868948_thumb.jpg post-24210-0-35704700-1305869055_thumb.jpg
The Rears are 18X9.5 with a +45 offset plus the spacers comes down to +33 offset. The tyres are Nankang Ultra Sport NS-2's in 265/35 R18's with 5mm of tread. 1 tyre has been used while deflated and has marks on the sidewall and looses pressure.
post-24210-0-51516500-1305868919_thumb.jpg post-24210-0-37539700-1305869003_thumb.jpg
Check pictures for the wheel's condition. There is some light crazing on the clear coat of the polished lip, and some gutter rash.
I'm asking $600 for them ono.
I'm located in Wollongong NSW, for Sydney buyers I can meet you at Heathcoate McDonands to save you a trip to Wollongong or I would be able to post them at the buyers expense.
If you're interested contact me by pm.
Charles.
These wheels are worth $1700 new for the wide wheel pack from Tempe Tyres, so they are 1/3rd of retail.
http://www.tempetyres.com.au/products_closeup.asp?part=&part_no=294
  • 1 month later...
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
