This has been doing my head in recently so I need to find out more info before I spend money on something that aint going to work.
So basically as most people know, Volk GTC wheels require special Rays Lug Nuts to make them fit. These lut nuts look like this:
They are expensive, don't look all that great and if you loose/break one you are pretty screwed.
Everyone uses these as they are basically the only option and no other lug nuts fit.
However when I bought my wheels I thought that maybe if I got longer wheel studs it would allow me to run normal lug nuts.
Turns out it works and I run normal open ended lug nuts like this:
So my question is. If I now run normal open ended lug nuts as above, does that mean that I can now run some form of Rays lug nut?
I really want some black lug nuts that are closed on the end. Not open ended because it looks all crappy rusted inside.
The issue is the diameter of the lug nut. As on the GTC wheel they go completely inside and actually "lock in" towards the middle of the wheel instead of right on the outside.
But if you look at a picture such as this of a different type of aftermarket lug nut, it appears that something might work since it looks to be the same diameter as my one on the far right?
Thoughts? I'm getting to confused by constantly looking at different pictures of lug nuts and I just want some damn black closed ended lug nuts lol.
https://www.sau.com.au/forums/topic/365010-volk-racing-gtc-wheels/
You can get the racing spec D1 lite-weight racing nuts and they should fit fine. Looks good too. They cost around $110. Don't be fooled by Ebay copies. Get them from JustJap, Nengun etc.
Cheers.
See the main thing that I keep thinking is that maybe a socket won't go over it since they sit all the way inside the wheel and there simply won't be enough room? Hence why the Ray GTC lug nuts are open ended since that is all you will ever fit.
Here a picture is worth a thousand words. Will explain the differences.
After drawing that I really don't fit there is any other options than what I allready have.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
