headlights - $350 ono
LHS tail light - $40
RHS tail light (okay condition) - $20
door cards - $40 each
doors - $40 each
door sil plastic trims $30 each
Dash - $100
Instrument cluster (141,000km's) - $120 ono
brake master cylinder - $ 80
Handbrake boot and surround console with compartment - $80 ono
Standard shocks and springs all round ( great for clearing defects) - $200
Radiator fan - $30 ono
Boot rubber trim/seal (in good condition) - $30
Front Bar with bottom cut out for intercooler could do with a respray - $20
boot lid - $20
front quater panels - $20 each
few other little bits too
just hit me up !
  • Replies 51
Do you have any seat rails?? I'm in need of a drivers side one if you have, and maybe after the guards! Where are you and what colour is the car??
Edited by Slow4door
SOME PRICE DROPS
NEED THIS SHIT GONE ASAP !!!!!!!!!!!!!!!!!
headlights - $300 ono
doors - $40 each
Dash - $100 ono
Instrument cluster (141,000km's) - $100 ono
brake master cylinder - $ 60
Handbrake boot and surround console with compartment - $60 ono
Standard shocks and springs all round ( great for clearing defects) - $180
Front Bar with bottom cut out for intercooler could do with a respray - $20 !
boot lid - $20 !
buuuummmmmmmmppppp
SOME MORE PRICE DROPS!
Dash (decent condition) $80 - If sold within next 2 days
headlights $250 firm - If sold within next 2 days
perfect door cards $40 each !
perfect doors $40 each!
stock springs and shocks - only $150!
much more stuff aswell
hit me up
very neg.
0408391831
    • Hi all. So one of my major issues at the moment is my rear turbo leaking oil on the exhaust (and the general area). I presumed it was the rock hard super old drain hose, which it was not. So now I am in the midst of removing the rear turbo to get access to the banjo bolt that goes into the turbo oil feed. As one of the previous owners accidentally? tore off the OEM oil feed hardline that reaches behind the turbo, they ran braided lines directly to the turbo, presumably PTFE. Now, regardless if the line has rubber or teflon inside, is it just generally a bad idea to do this? I imagine these lines get quite hot being between the engine, turbo core and exhaust manifold. I suppose it's not too far fetched to think the line may even have melted. I'd love to hear your opinions on this as as the replacement OEM hardline piece is 130 per unit. And cutting open the currently mounted line to see inside will mean I just have to get a replacement either way. So far I am hoping maybe the bolt just loosened or (god forbid) they forgot one of the crush washers.
    • If it's a factory 20de manual probably has the 6 bolt flywheel in which case the det clutches won't work as they're 9 bolt.
    • All RB push clutches are interchangeable. AFAIK, the 4cyl ones are not. Different flywheels. The RB small box is not identical to the 4cyl boxes. Just very similar.
    • Hi. I need a new clutch for my gearbox. It is a factory smallbox behind RB20DE NEO. What options do i have? If iam not mistaken the gearbox should be the same as in R32 GTST and Nissan S14/S15? I found some Xtreme Clutch Stage 1 for S14/S14 (i dont know if you know the brand) (UK) OR...is the clutch same as in the bigbox from RB25DET?   Thank you!
    • Listening to an artist called "the flashbulb". Not bad. Makes some fairly well researched youtube vids in various things.
