hey guys,
i need some help, my brakes lights arnt working but my rear park lights are, so it cant be a fuse. I recently pulled my dash out and fitted white dash so there is a good chance i knocked something on the way, i dont know what im looking for...
im thinking it must me something to do with the brake pedal switch thingo...
can someone please point me in the right direction??
thanks guys
It can be a fuse - the brake lights and tail / park lights are on two separate circuits.
Unlikely that all four would go at the same time, but you've checked that the globes are still OK?
There is possibly a fuse in the block under the steering wheel (don't know 33s that well).
The globes are "twin filament" type - one filament is the tail / park, and the other is the brake. It's possible for one filament to blow and not affect the workings of the other filament.
The fact that your hi-level brake doesn't work as well suggests a fuse. Or the switch on the brake pedal has been disconnected / broken.
with the 33's is there a "sensor" at the peddle, at the back of the stop peddle there my be a thing that when you stop, pressing the peddle depresses this button which sents the signal to the lights to get them to work, it may be the problem, if its there adjust it ?? then again if the 33's don't have this thing then its something else!!
It's a simple on-off switch. When the brake pedal is "up", there should be 12V on one side of the switch. When the pedal is "down", there should be 12V on BOTH sides.
Bingo.. :( thats the thing that stopped my stoplights from working all i did was adjust it and they worked fine, hope this is the case for the 33's??
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
