went to mates private property and did a run , speedo kept going past 180 and but figure it must be out a bit though it went near to perhaps a 200km mark , then backed off as was running out of road
Also have purchased a Speed Meter , though R6n350gt has put a tutorial on how to install up will be taking the car to auto elecs to hopefully sort out the delimiter using the Speed meter , will keep track of results and post up once done , if it is figured out then $135 is a good price to delimit car , as well as recording 1/4 mile times,
  • Replies 42
Yeh you can deff recal it. there are shops in syd that can do it.
Please: do tell how!
My V35 sedan is very much out of whack due to tyres/wheels, and I have been quoted many, many hundreds of dollars to have the recalibration (to within +/- 1kmh) done.
As mentioned before, the speedo guage stopping at 180 can be solved with the nismo guage set which runs upto 280 kmph. The actual speed limit can be fixed with various speed limit removers. Most jap tuners that make electronics make them. The pivot one is probably the most reasonably priced at only about $150 delivered. They have digital speed display upto 350kmph and they remove the speedcut.
Here is the link on nengun
http://www.nengun.co...t/speed-meter-v
Even if you have the nismo gauges already so dont need the digital speed too, these units are still cheaper than all the other speed limit removers. Cant confirm compatibility as i havent looked into them too much. HKS and other brands also make speed limit removers but are more expensive, the HKS ones are around $350 but i think they are model specific.
If youre having issues with speedo being out, your probably better off picking up a guage like scanguage or something that reads speed off the ODB port and allows for adjustments. I know the scanguage does allow adjustments in the speed as i think they are originally designed for 4wd's which often run larger wheels and have speedo issues. You can pretty much just put in a % correction for what it displays on the screen. This could be worked out with a tire size calcualtor to see the % speed difference and confirmed as correct with a GPS.
Edited by Ben-88
The HKS one should work at least but I wouldn't recommend cutting the CAN line to install it, all your speed data goes down the CAN line, there is no speed signal wire going to the ecu to bend. Just get an aftermarket ecu from Japan.
i just did a googled speedo recal sydney found some places but call around a few performance places they should be able to do it, Croyden auto sports should be able to do it.
Who would you have to see to have that installed Ben?
Well thats a good point, a bit risky cutting into the can line.. all these new bus type setups are awfully complicated to work with when there arent plug and play electronics available. Not sure where you would have it installed, or rather who you would trust to have it installed.
It seems the pivot unit at least has been confirmed as not working for speed limit removal in this DIY article http://www.skylinesaustralia.com/forums/topic/364333-pivot-speed-meter-v-diy/
but the speedo does work for anyone that wants an alternative to the nismo guages.
Fortunately for us though, as mentioned there are many tuning companies where you can just buy an already flashed ecu with speed cut removed and other features. They fill up like a whole page in hyper REV.
Hmm i think the best option is going to be to get the nismo dash to keep the car looking clean on the inside and get the ECU flashed or replaced gona be expensive but will keep the car looking clean on the inside which is what i like.
*skips all posts
I have an apexi thingo ma bob which removes the 180km/h limit.
I hit 200km/h and it makes a buzzing sound.
edit: Or you can use your apexi hand controller to record your top-speed.
but srsly i'd look down, 200km/h isn't that fast.
Edited by SKITTLES
*skips all posts
AAAAAAAAND you have a car that uses a single signal wire to the ecu that the apexi interrupts and changes
the V and M chassis use the CAN network to transmit it
its the communications network that many of the devices and sensors use to communicate to the ECU and each other.
if you cut it, it MAY sever some essential communications. what if the ECU needs to see your speed when you hit the brakes and ABS kicks in? what happens if your engine stalls every time you pull up because the ECU didnt know you were moving.
there are hundreds of potential problems. and many people will ignore scott's warning, and this one. but its your car, cut away!
This makes me think it will be better just to install speed meter for display of speed and Other settings rather than cutting this wire , really don't want to stuff up the speed signals
best advice, ever lol
Also with the pivot speed meter it can tell you how fast you went with a press of a button. So dont look, just drive then once you have stopped or slowed you can press to see what the max speed was and the max g-force in acceleration and breaking :) 188 was the most i could get out of it with a quick run on private road. I have not tried to max it out yet..
As to another ECU, i was on the verge of getting a technosquare flashed ECU from a 350Z but even though it would match up i would have to get my keys reprogrammed so the BCM would work with the immbolizer again
If you gonna do all that crap you may aswell get a pivot speed meter and a Utec EMS which has got speed limit removal feature and then you can get your car tuned and get more HP out of it... be cheaper that nismo gauge, flashed ecu, reprogrammed keys etc..
Pivot speed meter is easy as piss to install, the Utec will be too (dont worry ill write a guide lol) and then get a tune. $200 an hour, 1-2 hours max if still NA.
So $150 del for pivot speed meter
$400-450 for Utec delivered (second hand)
Install both yourself = free
tune $400
Total *ish $950 for a tuned car, more HP (usually 8-10RWHP from a tune once u have bolt ons), delimited and a speedo upto 350km that can record top speed, top g force in acceleration and braking, show g force on the fly, and do 100,200 and 400m timed runs :)
If you go 280km speedo $600-800
HKS delimit $300-$400
Install = who knows.. $200+
Total *ish $1100 min
Edited by R6n350GT
    • That's the thing. Especially at idle, changing the cam angle by that much could be spewing more fuel out the exhaust courtesy of everything happening that bit later. More fuel also means more air (if the fuel didn't burn, then neither did the O2) and so the O2 sensors can start to tell interesting but misleading stories. And the specifics of what is happening could easily be affected by everything else you changed as well. And it could be dynamic, where a few revs more or less could somewhat change how the engine is breathing.
    • Good idea on the temp probe. The mv readings of the O2 sensors are very similar to one another, as is the injector pw. I went through logs in the past to see if there was a discrepancy and there is. Because they alternate up and down as narrowbands do.. they do often 'switch' as to which one is more. They were never 20%+ (more like 1-2%) so it's possible the difference between 20 and 15-17% is a similar discrepancy to 2.0% and 1.7% which I wouldn't have really noticed in the past. We did think about spacing the strut brace. Unfortunately the ~20mm that the GTR brace is lower than the GTT brace is effectively what you need to clear the vents. Moving it up would make it very uncomfortable, but it's plausible that 10mm is a unhappy medium between both hard places... The good news is.. using MR HAMMER it was actually pretty easy to bend back the bent bits to make sure the guard and headlight/new headlight tabs line up right. Yes, we used a R34 GTR guard to make sure the bolt holes all lined up with a known straight guard. As above, you can see the side skirt and the GTR guard are not meant to play together, but everyone seems to think this is a simple fix to the point where nobody who has had these talk to one another mentions how... ...so I'll just assume they know how to fix it when it comes to paint jail time again. Whoever they are. Nobody returns my calls. There's so much changed with regard to the ECU and the car.. that the next step really is to connect the scanner and attempt to drive the thing. It'll be pretty clear pretty fast how in or out everything actually is...
    • That's nasty! I think there is perhaps an inherent problem is using elastomers in such environments. The whole thing can and will get quite hot, and elastomers are not famous for their temperature resistance. On top of that, if the components are cast rubber or urethane and so on, there might be QA/QC problems with bubbles or voids in the material that could critically change their performance. They might just tear apart after being squished (presuming that any elastomers are used in compression rather than tension, I'm thinking that you squeeze one with a void in it and it tears the wall of the void to the outer edge of block, then the next time it extends or otherwise twists, it just gives up). This is all purely hypothetical, but it makes me wonder if the things that they have put into it to make it nice to use/live with are perhaps going to cause occasional failures like this. I wouldn't be getting up in arms over it, unless there are many repeats. I have personally ruined an Xtreme clutch - just an HD thing. I can't remember if it was still behind the 20 or was after the 25 went in. But it inverted some of the retaining spring/clip things around the outside. No-one could explain it. It wasn't thrashed, there wasn't heaps of torque being put through it, and there were no obvious problems other than the above. They were quite concerned by the event so they replaced it even though it was a few years old, which was very nice of them. As far as I am concerned, these things happen with clutches.
    • Any damage to the box/input shaft?
    • Hey there Mate , I just got my local guy to install it Waterhouse Performance, Penrith (specialise Nissan/Datsun and other performance cars) , you can do it yourself if you like , AMS has instructions on their website.  Cheers Pac
