:action-smiley-069: Hi Guys and Girls...
Just need to know what mods is essential to drift R33 skyline GTS-T .......... I want a drift setup in my skyline not for proffessional use but just if i go on track so i can drift my car properly with full control and less body roll......... was watching few videos on you tube and these guys were amazing ........... Just need to know that do i have to change the DIFF as well ???? and as i think need some power at the wheels as well so how much RKW at least i need to drift my car easily........... do i have to buy coilovers as well ???and whtat other mods i need ???? so if anyone can help me with this setup then it will be highly appreciated ....thanks
coilovers, ~8/6 for street/track or ~10/8 for track drift only
swaybars - whiteline adjustables or selby's are an easy option
diff - you can buy a locker from kaaz USA fairly cheaply at the moment
at a minimum this will make it a lot easier to control
thanks guys for your replys.............. but how much KW at least i need at the wheels ........ as i think this is the most important one............ and how much all up it will cost me (Drift Setup) ,.............Thanks
Most of the guys on here who are involved in any kind of motorsport, rallies, circuit, drift whatever will tell you that suspension and body control are not only more I mportant than power at the wheels but you will achieve a greater improvement for a lower cost, so as above start with a diff, 2 way is best but u can get the diff shimmed to lock it up as a start, coilovers,and some stiff swaybars, costwise it depends how far u want to go and how much u can do yourself, probly 2000 will get u some 2nd hand coilovers a shimmed diff and a rear sway bar probly with change.
for basic drifting you need 200rwkw
imho sell your car if its stock and buy a modified GTST already with this power level
otherwise
going from stock to 200rwkw + basic drift setup
ecu 1000
tune 500
exhaust 1200
tyres 600
suspension and diff setup 1000
new diff 1000
good intake 350
boost controller 300
intercooler 600
fuel pump 300
clutch 1200
doesnt include coilovers
doesnt include new diff
should get some change from 10k
be prepared to bin your car and if its your only car rethink if you are ok with loosing your car
many have done so before
Power isn't important at all.
Skill & car setup are far more important than power.
you could get away with just an ecu, exhaust, fmic, clutch and suspension no worries
nistune - 800
2nd hand fmic - 300
hd clutch - 500
2nd hand coilovers - 700
2nd hand swaybars - 200
welded diff - 100
R32 actuator - 20
that's $2620 for a fairly easy to drift setup that should yeild ~180rwkw
but as has been said, power is not that important for drift, it's all in the suspension and handling setup
my ke70 only had like 70rwkw and it was easy enough to slide
hi Guys,,,,,,,,,,
Thanks for replys and great help............. Yes, I got pretty much stock car at the moment......... Only Mods are FMIC , Exhaust , BOV and I just did a dyno run and it was 165Kw ............ So i decided to buy the Coilovers and aftermarket ECU.................. The list of stuff that is sitting in my Garage is as below
1. Tein HA Adjustable coilovers (Second Hand) ----- $800
2. Apexi Power FC (Second Hand) ----- $1000
3. Apexi Electronic Boost Controller (Second Hand) ------$450
4. Apexi air filter kit (Second Hand) ------$350
5. Defi Guages (Boost and Oil Pressure (Brand New) ------$400
6. Autometer Tacho (Brand New) ------$200
All this stuff is sitting in my garage collecting dust as I spended all my saved up money to buy this suff and now i don't have enough to put them in......... Anyways, the only things i have to buy now is Two Way Diff and Sway Bar according to you guys to complete Drift Setup............ Any good place in Victoria where I can take my car and all the above mentioned stuff and other stuff (Diff and Sway bar) to put them in OR Sell this car and all that stuff and buy a Modified Skyline................. Any recommendations??????????????????????????????????????? Thanks
Hektik points are good for rwkw you should know that by now Paul. Also, they will match his veilside kit :D
as for Recomendations, put all the stuff on your car and go sliding, if you want some more power ( and I would too ;)) get turbo hiflowed with steel wheels so it can handle 18 pounds of boost, about 1000$, plus tune will be 500+ this will give you plenty of power (210kw) for learning and one thing nobody has mentioned strangely enough, a hicas lock bar, which is probably more impotant than anything else.
otherwise
ecu 1000
tune 500
exhaust 1200
tyres 600
new diff 1000
good intake 350
intercooler 600
fuel pump 300
clutch 1200
nistune - 800
2nd hand fmic - 300
hd clutch - 500
welded diff - 100
R32 actuator - 20
ya'll tripping.
my car slides fine stock power, fmic,exhaust thats it.
weldy, coils,swaybars,solid bushes or whatever there called 2 drift days not an issue.
clutch is still going strong. Just get out there have a crack mate dont worry about these high rollers.
thats the best advice yet alr33x :thumbsup:
another thing I forgot to mention why not just fit all the stuff to the car youself, there is plenty of info online how to do stuff. I dont know what im doing but I reckon I could fit most of that stuff in a weekend with some help from my old mate google
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
