I'll start with I've never pulled down a gearbox but am interested to try and learn.
The gearbox is OK and silent in all gears, the transfer case can always spin the fronts as well as the rears, but if you quickly put it into fifth at anything above about 80km/h, it'll crunch. It also won't go into fifth at over 140-150km/h, causing major suckage down the straights at Sandown.
Would anyone have a diagnosis?
Is pulling down a gearbox and checking/replacing synchro's and other parts a DIY job for someone who does practically all work on their car?
If so, what should I know?
If not, who should I take it to and what are the typical costs?
If not again, do R32 GTR gearboxes often break or not, therefore I should chance it with a second hand box?
Thanks
Yes that sounds exactly like the symptoms of the (common) worn synchros. No you are unlikely to have any better luck with another 2nd hand box because they all have 22 years of being abused just like yours :P
I recently had a second hand 32 box rebuilt, it cost about $2000. That cover upgrade to 33 series 3 parts (you cannot get 32 parts any more) including all new synchros. All new bearings. Strip, clean, measure and reassemble. From the guys at Award Gearboxes in Seven Hills, they have done heaps of GTR boxes.
    • Hey everyone, just wanted to let you know about an app I use to track the modifications, repairs, servicing etc I do to my R33 GTR. You might like to use it as well. I'm biased because my son just wrote and released it! But I think you might find it useful to... https://trackmymods.com
    • Hey everyone, been on here for a while, but never introduced myself before. 1st import was a R32 GTS Type M, then R33 GTS, now R33 GTR - each one sold to help pay for the next one. Over the years my son has seen me modify and do changes to my imports and was one of the reasons for him to build an app for car enthusiasts like us. (He can only afford a 2007 Honda at the moment, but he'll get there!) Anyway, bit of a proud Dad moment as he's released an app that I use and you all might like to as well. https://trackmymods.com
    • It will sound tragic and you wished you didn't have 1x exhaust per turbo. There's a reason why most S55 owners change to a single mid pipe.
    • Echo the comments about the well preserved condition it's in. It has the aero bumper too for extra points. Nice car, and please keep it like that! 馃檪
    • 1. There are no real performance benefits. It sounds different, and as the pipes are not as large diameter you can claw back some undercar clearance or run lower (if that's your thing). 2. Twin pipes, offering exactly the same cross sectional area as a single pipe** will have higher pressure drop - so will not flow as well. That's because there is more surface area of wall per cross sectional pipe area, hence more frictional losses. ** But of course, it is almost impossible to get 2 pipes that are exactly the same XS area as a given typical single pipe. eg, 2x2" is not the same as 1x 3", although it is close. If the 2x pipes add up to less XS area than the single - it will just be flat out worse. If the 2x pipes add up to a bit more than the single, then it might come out as a wash. If the 2x pipes are substantially more XS area than the single, then it will probably flow a little better. 3. No. Why would there be? What have cats got to do with boost creep?*** ***But for f**ks' sake, please run a cat. 4. If you want.
