Oil Shooting Out Of Dip Stick
TJR32GTS-T
 Share
Hey guys, I've noticed abit of oil around the drivers side of the engine bay and it appears that it is coming out of where my dip stick goes in as the dip stick is popped out everytime I check, I am going to order a new dip stick because of heard that the seal can be rooted, what are the other causes of this and how bad can the problems be?
Cheers in advance - trent
I will check, I just read that a incorrectly plumbed catch can could be an issue? I bought the car with one on have never seen a drop in it. Just a thought
Yeah, a catch can that hasn't been installed properly can cause abnormal crankcase pressures dude. There's a massive guide somewhere on this forum about all the possible ways to correctly plumb in a catch can. Can't remember the thread name but just search "oil catch can" and it'll find something.
If you want to track down a new dip stick as well, go to Jerry again. He got back from Japan last week. I remember him having a crapload of RB dipsticks laying around his workshop.
Edited by GT32
Sweet dude I'll give him a call, he posts his stuff doesn't he? It's just a pain in the arse driving to epping from the east, I'll check out another place I found this week aswell.
To be clear, the reason the crank is pressurising is that blow-by is getting past the rings - but, that can happen even on a relatively OK motor. The fact that it's pressurising the crank to the point of the dipstick popping out may be a cause for concern.
The pcv valve (positive crank case ventilation valve) is intended to vent the crank pressure. If the valve is gunked up, it won't be doing that job properly. Not hard to remove and clean, check operation.
An incorrectly plumbed catch can will stop the thing venting if it's effectively plumbed in a loop. Basically you want to leave the factory route between the PCV valve and the inlet tract the same, and just intercept it at some point with a catch can. The basic route should not be altered.
I'm not sure if he posts anything but just call him and ask, you never know. I've never needed to get him to post anything as I've always gone in there because my gf lives around the corner from him.
Cheers dorifticon, that explains alot, because I'm not that mechanically minded but pretty handy with tools how would I go about cleaning the pcv valve? A picture of an rb20 where the valve is would be awesome, I will also post a pic of the current catch can setup,
Cheers
ok here are a few pix and a diagram i drew
alot of the oil in the engine bay can be explained by the outlet (which cant be seen in the ppic because it is at the bottom faceing the strut) on the catch can, but some of the spray appears to be from where the dip stick is
Edited by TJR32GTS-T
2 issues here:
1. Yeah that catch can isn't plumbed correctly ...but it's more just a case of it being 50% effective (at best) rather than causing a pressure build up. The two cam covers should be connected directly by a hose and the catch can plumbed into the line going out the right hand side of the diagram - between right hand side cam cover and intake pipe.
2. Unless.....the PCV valve isn't working. See the hose coming from the manifold and onto the T-piece? Is the 1-way valve working to stop manifold pressure from entering the cam cover at the t-piece.
Sorry I only know how the R33 one works (which has a 1-way valve) at the cam cover.
ohhh and where does that right-hand side pipe end up? hopefully in the intake before the turbo. ie stock location.
Edited by simpletool
Ok so if there was a hose bridging the 2 cam covers would it be efficient? They are kinda technically bridged but through the catch can. Also what do u make of the 3rd outlet on the catch can? I would imagine the catch can wouldn't fill because the outlet is at the bottom(see diagram) other setups I have seen have that outlet up the top with some sort of filter.
Also I'm not sure how to check the pcv valve?
Thanks for your input :)
There should be not outlet on the catch-can, other than the drain plug. That drain plug has the plug in it....right? Otherwise you are drawing in unmetered air through the catch can.
Anyway, I've put some details in the photo. post-23086-0-67816600-1306199969_thumb.jpg
Dont' mind my other comments, I got a bit carried away.
The PCV valve should only allow air to flow INTO the manifold, but not from the manifold and into the cam cover. You might have to check other threads for the RB20 PCV valve and where it is. you can test by blowing into it each way,
 Share
    • So, as it turns out, a new wire was the answer I went for, but getting there was not straightforward... Firstly, I'd been told before by shops that had worked on the car that it had some weird factory wiring, and I can now confirm that is true in at least a couple of places. For example....that very purple/white wire that provides IGN power to ECU pin 31.....I traced it out of the ECU loom into a connector high on the nav's A pillar under the dash, where it headed up and out of site across the dash, then back down at driver's A pillar. After trying about 8 different relays I found it coming into the back of the fuse box, and confirmed it was the same wire with a multimeter* (more to follow on that.... So, which fuse is the ECU IGN power connected to in my car?  Very top right, labelled IGN (good), 10A (good), Auto Trans Control (WTF?). It's not impossible it has been f**ked with before, but if so someone removed the pins from the back of the fuse box and moved it somewhere else, noting an AT control fuse would be functionally useless as the car was auto converted to manual long ago. It is not simply a wire cut and joined to the wrong place, both ends of the wire are the same colour just one is in the wrong location (you can see there is an IGN Engine Control fuse in the bottom row 4th from the right. Note, that is the fuse box sticker from my actual car, so either I have the wrong coin holder sticker, someone f**ked with it post factory, or factory sticker does not match the wiring.....whichever option it is just plain weird. Undermining the likelihood of someone having gone to that trouble to move a power feed when everything else in the loom had already been butchered....the fuse next to it IGN 7.5a ABS doesn't even have a wire running to it....so no idea where that fuse is on this car. All strange. But not the problem with my ECU power.
    • New tank clean paint and install complete 🤙
    • I have heard the frenchys kit (with the smaller toyota compressor) performs fantastic. i havent actually gassed my system yet, so cant confirm myself..
    • https://www.efisolutions.com.au/injector-lower-manifold-collars-adapters-r33-a32-y?gad_source=1&gclid=EAIaIQobChMIjpXb2aLaiAMVYcA8Ah1zkg6JEAQYASABEgJzG_D_BwE
    • correct Ive moved to a r33 oem ball joint - they are actually thicker than alot of the after market and similar
