Hey guys, I've noticed abit of oil around the drivers side of the engine bay and it appears that it is coming out of where my dip stick goes in as the dip stick is popped out everytime I check, I am going to order a new dip stick because of heard that the seal can be rooted, what are the other causes of this and how bad can the problems be?
Cheers in advance - trent
https://www.sau.com.au/forums/topic/365171-oil-shooting-out-of-dip-stick/
Yeah, a catch can that hasn't been installed properly can cause abnormal crankcase pressures dude. There's a massive guide somewhere on this forum about all the possible ways to correctly plumb in a catch can. Can't remember the thread name but just search "oil catch can" and it'll find something.
If you want to track down a new dip stick as well, go to Jerry again. He got back from Japan last week. I remember him having a crapload of RB dipsticks laying around his workshop.
Edited by GT32
Sweet dude I'll give him a call, he posts his stuff doesn't he? It's just a pain in the arse driving to epping from the east, I'll check out another place I found this week aswell.
To be clear, the reason the crank is pressurising is that blow-by is getting past the rings - but, that can happen even on a relatively OK motor. The fact that it's pressurising the crank to the point of the dipstick popping out may be a cause for concern.
The pcv valve (positive crank case ventilation valve) is intended to vent the crank pressure. If the valve is gunked up, it won't be doing that job properly. Not hard to remove and clean, check operation.
An incorrectly plumbed catch can will stop the thing venting if it's effectively plumbed in a loop. Basically you want to leave the factory route between the PCV valve and the inlet tract the same, and just intercept it at some point with a catch can. The basic route should not be altered.
Cheers dorifticon, that explains alot, because I'm not that mechanically minded but pretty handy with tools how would I go about cleaning the pcv valve? A picture of an rb20 where the valve is would be awesome, I will also post a pic of the current catch can setup,
Cheers
ok here are a few pix and a diagram i drew
alot of the oil in the engine bay can be explained by the outlet (which cant be seen in the ppic because it is at the bottom faceing the strut) on the catch can, but some of the spray appears to be from where the dip stick is
Edited by TJR32GTS-T
2 issues here:
1. Yeah that catch can isn't plumbed correctly ...but it's more just a case of it being 50% effective (at best) rather than causing a pressure build up. The two cam covers should be connected directly by a hose and the catch can plumbed into the line going out the right hand side of the diagram - between right hand side cam cover and intake pipe.
2. Unless.....the PCV valve isn't working. See the hose coming from the manifold and onto the T-piece? Is the 1-way valve working to stop manifold pressure from entering the cam cover at the t-piece.
Sorry I only know how the R33 one works (which has a 1-way valve) at the cam cover.
ohhh and where does that right-hand side pipe end up? hopefully in the intake before the turbo. ie stock location.
Edited by simpletool
Ok so if there was a hose bridging the 2 cam covers would it be efficient? They are kinda technically bridged but through the catch can. Also what do u make of the 3rd outlet on the catch can? I would imagine the catch can wouldn't fill because the outlet is at the bottom(see diagram) other setups I have seen have that outlet up the top with some sort of filter.
Also I'm not sure how to check the pcv valve?
Thanks for your input :)
There should be not outlet on the catch-can, other than the drain plug. That drain plug has the plug in it....right? Otherwise you are drawing in unmetered air through the catch can.
Anyway, I've put some details in the photo. post-23086-0-67816600-1306199969_thumb.jpg
Dont' mind my other comments, I got a bit carried away.
The PCV valve should only allow air to flow INTO the manifold, but not from the manifold and into the cam cover. You might have to check other threads for the RB20 PCV valve and where it is. you can test by blowing into it each way,
    • I'm at the point of seriously starting a project to build and Arduino/mc (of some sort) based multigauge to go in the console where triple gauges normally sit. I have found a screen of the right dimensions. I would need to 3D print a bezel/housing to make it mount up pretty. That's doable. I would need to come up with interfacing circuitry for the EGT thermocouple. I'm sure there will be examples of that into Arduino out there somewhere. Ditto with characterising the output of the existing boost gauge's MAP sensor and the oil T gauge's thermistor. And then, because it is a screen, it can be controllable, so it can show more than the 3 gauges I currently have. So I can come up with a list of other things I want to be able to show on it that can be reasonably easily handled via an Arduino's inputs. I do not need this project. But the stepper gauges I'm using are giving me grief. It's time to come kicking and screaming into the 21st century.
    • Would you really prefer pillar gauges over something like this? https://www.haltech.com/product/ht-067010-haltech-ic-7-digital-dash-kit/ Or if you can spend more, this? https://www.haltech.com/product/ht-068000-haltech-uc-10/ I could write a thesis about how much better a modern dash is compared to a series of gauges.
    • People think it's a waste of space, ugly, etc, generally associate "emissions control equipment" with "bad". These OBD1 vacuum-only systems I'm not a huge fan because I think they don't go far enough. They're wasting some of the fuel captured because they start purging as soon as the engine pulls vacuum. Later OBD1/OBD2 they put an electric purge valve on them to vent only when closed loop is active so the ECU will trim some fuel out. Even later OBD2 with zero evaporative loss the tank is 100% sealed from atmosphere until you run the engine or press the refuel door release. The tank has to take much higher vacuum/pressure spec but you never deal with saturating the charcoal canister and losing some fuel that way. The fuel also lasts as long as it would in a 100% airtight container which is nice when you're dealing with modern E10 pump gas.
    • If your luck is anything like mine, what happens is in the process of pulling hoses to get access to the one leak you create many more leaks because every o-ring was on the verge of failing and the strain of pulling it apart caused it to fail. Sometimes life is simple, sometimes you pay twice trying to save once. For the R33 you can still get most AC components from Nissan, I use nissan epc data or amayama to look up the part numbers and then search for the cheapest/most practical way of sourcing from there.
    • The dirty secret is there is nothing recyclable about the plastic bag or old plastic bottles either. Our local trash collection explicitly calls it out as hazmat in both cases. Oil-soaked rags + paper towels too. Oil-soaked cardboard is also not recyclable. The most common case of oil-soaked paper like that is pizza boxes, which are explicitly compost-only from the oil. To my knowledge hazmat oil contaminated plastic the only solution is either landfill or "thermal recycling". Most plastics in my experience there is slow permeation of the oil it's holding into the container so it's very challenging to get it 100% clean.
