it's been proven before that you don't need the plenum changed unless you are flowing enough air for over 450hp.. also as mentioned before, it is a bastard of a job to do yourself and very expensive to make someone else do it for you (unless you know people in the trade who feel that they need a huge headache)
LOL GTST!
Your making it out like its rebuilding a motor! Its about 2 hours of welding & 2 hours of precision cutting & filling.
Its not that hard to do, provided you can weld aluminium. Lining it all up is the hardest part.
WLD747, ask around at Jap wreckers. youl pick one up cheap enough. Remember you dont need any of the bullshit stuff, (THorttles, linkages. etc) just the plenum.
Cheers guys,
Trev
I don't think GTST (Tolga from memory) is having a go at you.
Rather he's saying that any forward facing plenum on an RB25 is a lot of work installing because you have to eff around with FMIC pipes, injectors, rails etc. etc.
If you have the motor out, well fine but for a in car install, all the shite on the right side has to come out and some cutting of the metal under the washer bottle.
People do it for looks often and fair enough.
T.
Hi
I have a GTR plenum on my r32...
I bought the car with it on, my mates dad did the job, and i bought the car off him.
going by what he has told me...
BITCH! of a job, took him about 2 months to do, this was obviously not consistant more a weekend thing and he did it all himslef. it is not running 6 throttle bodies.
In my opinion the benifit is great, the car has got heaps of top end power but due to the short runners it loses power down low. The original idea was to twin turbo the rb20 but he ran out of time/money and didn't go ahead with it.
I have owned the car for a bout a year now and haven't had a problem, the only thng is I need more boost to take full benifi of the plenum..
PM me if you want to see some pics of the engine bay.
thanks Tony.
That is what I was getting at.
the picture above is with the engine out of the car so I guess it would be easier.
I also wanted to make a point that on an RB20 or RB25, you would have to have changed a WHOLE host of other parts, and be making HUGE power before the standard plenums become the restriction.
there is nothing wrong with the stock plenum, just it becomes more of a cosmetic change rather than performance. But reducing i/c piping helps!.
So why not run fmic pipes back under the coola past the air filter to the stock plenum?ceramic coat & heat wrap the pipes in the engine bay?wouldnt this be a good enough setup so you get less heat soak due to less piping in the bay as well??/ (i know there are shorter runs to a GTR plenum but theres money to be saved here for other mods especially when you dont know if the change is for looks or performance)but as far as iv heard the stock plenum is reliable for 450hp.Is this true?Tell us whats the power your chasing.Is it for a future engine upgrade?surely a setup like this would run cool enough for those figures.And while ur at it why not get a vented bonnet to keep those temps under controll.... :flamer:
Many coolers do run back underneath and not over the top.
ARC and Apex do this.
Heat soak is not really all that important with FMIC as the gas velocity does not allow much heat to transfer.
Oh and I do have both an ARC cooler and vented bonnet :rofl:
I think again HPI and Ben Ellis set the standard with 292rwkW with the standard plenum and he's not the only one.
T.
My car has the stock plenum modified to face forwards instead of going over the motor, al-la gtr plenum, but sits at the stock hight and doesn't get in the way of anything.
I'm not entirely sure if it flows better or is better but it looks good and makes fmic piping a hell of alot easier, it will look even better with a good polish. Hope that helps, but i dont have a scanner to get pics... oh well :rofl:
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
